External power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - External power supply
Are there any problems w/ running an external power supply? I want to upgrade my graphics card but will need to also upgrade my psu...unfortunately I have a Dell slim 540s and the options for in-case psu's are slim to none. Any help will be appreciated.
Sponsored Links
well, you could get a new case as well
Reply to mindless728
- 0 +
Well, you can get something like this: http://www.frozencpu.com/products/ [...] Cable.html
and even ask some friends for some old psu and just put it in your case or (abstract) outside your case;)
Reply to szymek
thanks for the link...what I would like to do is get rid of the 250w that came w/ this comp and step up to a 550w...problem is that nothing fits this case....sure, I could buy a new case,transfer everything,so on.....Im trying to work w/ what I have, not spend alot of extra cash, thats why Im asking about external power. Thanks again.
Reply to schlegelli
- 0 +
External will be fine as long as you have the length of cabling required. it would make th pc run cooler as well
Message edited by xtc28 on 08-11-2009 at 12:33:46 AM
------------------------------ AMD, INTEL, ATI, NVIDIA. IT DONT MATTER. THEY ARE ALL GOOD JUST GET MORE.
Reply to xtc28
Thanks...my common sense told me the same thing but in the world of computing nothing that is sensible works. I just wanted the opinion(s) of some who most likely know more than me in the field of modding/building comps. Thanks for the feedback.
Reply to schlegelli
- 0 +
you bet
Reply to xtc28
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > External power supply
There are 1235 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
