I just bought a new motherboard (GIGABYTE GA-MA790XT-UD4P). I'm trying to decide if it would be better to use the onboard sound or should I use my old Creative Audigy 2 zs?
Link to mo-board: http://www.newegg.com/Product/Prod [...] 6813128378
I just don't know much about sound card tech, so I don't know if the onboard sound has surpassed my old card.
I generally use headphones and I mostly use my computer for gaming.
Sponsored Links
I'd use the expansion card, to be perfectly honest. Even though it older, it will sound better than onboard.
Reply to jay2tall
The Audigy is a real sound card not one of those just upgraded codec type ones. I'd hold onto it for a little longer.
Reply to jay2tall
since you have the sound card already why not try the onboard for a while and then install the augigy and let us all know if you can hear a difference through your head phones .
Im picking you wont unless the headphones/speakers are really good quality
Reply to Outlander_04
That's not a bad idea. My headphones are mid-range. My main concers would be which one handles directional sounds better and has fewer glitching/lag/etc errors. Of course, quality is important too but that's a lot harder (for me) to detect.
If I do try it out I'll post back with results.
Message edited by Negative528 on 05-07-2009 at 11:04:03 PM
Reply to Negative528
I still use onboard audio...:(...but it still works like a charm. I really don't think there is too much difference in the 2, Creative Audigy and onboard, but Creative seems to give a tiny boost further than the regular sound. Either way, you will get HD sound w/studio quality!!
Reply to Kill@dor
I do have 5.1 surround sound from Logitech...forgot to mention ^_^
Reply to Kill@dor
I own the Creative Audigy 2 ZS. And from personal experience its better than onboard for gaming.
But onboard sounds better for movies and multimedia.
Reply to cybot_x1024
I have an X-fi eXtremeGamer card. it was $80 and well worth it. I can hear stuff that i couldn't before. You know, people sneaking up on me. COD4 totally changed for me back when I bought it. Even with headphones I know exactly where the sound is coming from
Reply to jay2tall
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Sound Card Question
There are 651 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
