I'm reposting this because I realized that I posted it in the wrong section, here's my problem:
I'm a bit concerned with these numbers and I need to know if these temps are normal for a water cooled PC.
I have an i7-960 3.20Ghz overclocked to 4.0Ghz and under 100% CPU load in OCCT, real temp is showing 79-80 Celsius After 10 minutes of running.
Idle temperatures are sitting at 45-50 Celsius.
Vcore is set to 1.26
QPI/VTT is set to 1.35
I bought this PC from CyberPower and it came with a 360mm radiator with triple 120mm fans mounted on top exhausting hot air out of my Cooler Master HAF-X case.
I believe the pump is a XSPC Dual Bay Pump.
You can see from the picture below.
I already reseated my water block along with removing the thermal paste and applying my own thin film of Arctic Silver 5 but I cannot get the temps to lower.
Picture of cooling setup, the 360mm radiator is at the top:
Left part of the CPU block is "IN" Right side is "OUT"
What am I doing wrong?
