Radeon x1650 pro
Forum Graphic & Displays : Graphics Cards - Radeon x1650 pro
I just installed a new X1650 pro to try to improve game play on my computer until I can afford a newer system (money is a little tight right now so it may be a while before I can buy a new system).
It works great on everything .. except the game I want to play.
As soon as I launch world of warcraft the sign in screen appears breifly .. then the system reboots.
do I just have a setting wrong?
will I need to reinstall world of warcraft to get it to work right?
am I just screwed?
Sponsored Links
First, uninstall the drivers for your current card and make sure you've also uninstalled the drivers for whatever card you had before that. You may want to use a driver cleaner program to make sure... but I don't know any free ones for you. I use the software from www.drivercleaner.net
Second, make sure you install the latest drivers from ATI's website.
Third, make sure you install the latest version of DirectX 9 from Microsoft's website.
Now try to see if WoW will play. If it doesn't work then now you should try to reinstall the game. If that doesn't work...well it may be a problem with something else. Please list your full system specs.
Reply to grimreality
- 0 +
could be a power supply issue, how many watts is it?
Reply to ct1615
Driver Sweaper is a pretty decent free driver cleaner here: http://www.phyxion.net/
make sure you use the driver's uninstall method, or control panel's "uninstall a program" method, then run Driver Sweaper in safe mode to make sure you get all of the leftovers
Reply to twisted politiks
well it took a little digging through ATI's website, but I managed to find an updated driver in the"legacy" section that fixed the problem.
thanks for all your help :)
Reply to vince_74
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Radeon x1650 pro
There are 448 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
