Tom's Hardware > Forum > Homebuilt Systems > New System Build > Building a Phenom II system
Forum Homebuilt Systems : New System Build - Building a Phenom II system
Hi,
I am currently building a Phenom II system
I have already bought a GPU (XFX HD Radeon 4870 1gb) , a case (CM 690) and Seagate Barracuda 500gb
I still need to decide on a motherboard, DVD burner, RAM and PSU. I currently don't want to Crossfire but I don't know about the future.
The reccomendation:
For the motherboard, I don't know if i should go with DDR2 or DDR3.
For PSU, I don't know don't know how much would be enough for a 4870 1 gb and phenom II
My budget for the system is 1k but the everything is around 1.5k
I live in Canada so the prices are a little higher
Looking forward to your advice
Sponsored Links
Go for DDR3, it's going to be cheaper and easier to upgrade later, I recommend 4GB for now. (About 100$ in Canada)
For a PSU you'd be fine if you have a 500W one, but if you want to CrossFire at a later time, go for a 650W to be sure, I'd recommend Corsair or Antec Earthwatts. (Antec's 650W Earthwatts is about 110$)
As for the board, I usually build with ASUS boards, for them, M4A78T-E and M4A79T Deluxe, both are good, just check with your budget which one fits your needs best.
As for the chip himself, I guess you will be taking the BE one? Don't forget your fan on it if you do.
As for DVD, I usually don't bother much about, all I want to do is read and burn occasionally, although I've realized that Pioneer's are very noisy compared to LG's. So personally I stick with LG. And that's about 30$.
Hope it helped :)
Reply to Shnur
Shnur wrote :
Go for DDR3, it's going to be cheaper and easier to upgrade later.
This is really a FINE point and one I think hasn't been mentioned much. I wonder when we'll actually need more than 4GB though?
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
Its a coin toss between ddr2 and ddr3 IMO .
If I had the extra money I would buy ddr3 , but if I was on a budget it wouldnt worry me at all to run ddr2 .
By the time you upgrade a computer it usually comes down to replacing cpu/mb/ram as a package anyway . 4 gig is fine , more is not going to be used by almost all 2009 applications and games
Reply to Outlander_04
Checked the prices lately? :)
DDR3 1333 is maybe 10 bucks more than DDR2 1066. I think AM3 boards make sense now, and all the popular Intel boards such as the UD3P come in a DDR3 flavor..... You factor in that DDR2 prices have risen in the last two weeks while DDR3 has dropped, and where does that leave us?
Reply to Proximon
- 0 +
^ Time for AM3 + DDR3... :P
Message edited by gkay09 on 05-08-2009 at 12:27:36 PM
Reply to gkay09
With AMD I would wait at least until they have the DDR3 errata fixed. Right now running in dual channel is unreliable. Besides DDR3 doesn't give much of a real world performance boost (any that would be readily apparent to the end user that is).
http://www.techpowerup.com/img/09-02-12/60a.jpg
Message edited by evongugg on 05-08-2009 at 05:43:30 PM
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
AMD's latest Phenom II processors may experience unreliable operation when running more than one stick of DDR3-1333 or DDR2-1066 memory on a channel using standard JDEC voltages. AMD has instructed motherboard manufacturers to have the BIOS downclock DDR3-1333 to DDR3-1066 and DDR2-1066 to DDR2-800 to ensure stability.
http://www.overclockersclub.com/news/24052/
Reply to evongugg
- 0 +
<Generic copy/post from another thread. Doesn't completely apply due to your video card, case, and hard purchase. Further, you aren't limited by size.>
Recently just ordered parts for 2 new builds for friends. Both will be used for "light multi-tasking," but mostly "MMO Gaming."
Case: COOLER MASTER Elite 360 <They wanted "smaller" desktops than mid-towers. This case offers desktop and tower "usable" configurations, ATX MB usability, and decent price.>
http://www.newegg.com/Product/Prod [...] 6811119195
PSU: OCZ ModXStream Pro OCZ700MXSP 700W <Modular for case. Plenty of power for eventual duel 4770 Crossfire.>
http://www.newegg.com/Product/Prod [...] 6817341018
CPU: AMD Phenom II X3 720
http://www.newegg.com/Product/Prod [...] 6819103649
MB: GIGABYTE GA-MA790X-UD4P <Crossfire capability, socket AM2+, DDR2 ram usage>
http://www.newegg.com/Product/Prod [...] 6813128387
Ram: Patriot Viper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 <Fast timings at DDR2 800 in duel channel mode, AM2+ CPU socket limitation>
http://www.newegg.com/Product/Prod [...] 6820220335
CPU Cooler: COOLER MASTER GeminII S <Smaller profile for small case. Offers ability to directly blow air on ram if wished.>
http://www.newegg.com/Product/Prod [...] 6835103046
Thermal: ARCTIC COOLING MX-2
http://www.newegg.com/Product/Prod [...] 6835186020
Burner 1: LG Black 22X
http://www.newegg.com/Product/Prod [...] 6827136152
Burner 2: LITE-ON Black 24X <Retail for software.>
http://www.newegg.com/Product/Prod [...] 6827106291
Graphics Card: XFX HD-477A-YDLC Radeon HD 4770 <Expensive, but the warranty is nice. Crossfire in future.>
http://www.newegg.com/Product/Prod [...] 6814150366
Hard Drive: Western Digital Caviar Green WD10EADS 1TB <Case only allows for a single drive. Further, users requested disk space.>
http://www.newegg.com/Product/Prod [...] 6822136317
Wireless: ENCORE ENUWI-N IEEE 802.11b/g, IEEE 802.11n Draft 2.0 USB 2.0 802.11n Wireless Adapter <They requested wireless capability, but not "usually used." I don't know why, but you do what they tell you...>
http://www.newegg.com/Product/Prod [...] 6833180053
"Video Exhaust Fan": Rexus NMB-MAT (Panaflo) 80mm
http://www.newegg.com/Product/Prod [...] 6835705019
"CPU/Case Intake Fan": Scythe GentleTyphoon D1225C12B4AP-14 120mm
http://www.newegg.com/Product/Prod [...] 6835185091
OS: Vista Home Premium SP1 64-bit <They requested it...>
http://www.newegg.com/Product/Prod [...] 6832116488
Monitor: ASUS VW224U Black 22" 2ms(GTG) Widescreen LCD
http://www.newegg.com/Product/Prod [...] 6824236050
<No keyboard, mouse, or speakers at this time.>
Cost: Slightly over $1,000 US Dollars post mail-in rebates & shipping
Another $120 dollars would make it a Crossfire system if so desired.
Reply to terr281
AMD has said that DDR3 support is a BIOS issue and not a CPU issue. I'm sorry I don't have the link right off. I read too much and sometimes loose track of where I get info :)
I'm still coming down on the DDR3 side, but it's a valuable argument right now.
Reply to Proximon
There are 1170 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
