Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Hello please advice on Power issue
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Hello please advice on Power issue
Hi I'm Steve and glad to join the experts community. I seek your advice. I have a powering issue on my comp. Whenever I power on my puter, it turns on for a split second (fans start, LEDS light, etc.) but then turns off instantly for like 2 seconds the powers on again and stays on this time. My specs are below.
Motherboard: ECS P45T-A
PS: BFG GS-550 550 watts
CPU: Core 2 Extreme X6800
Fan Heatsink: Scythe Katana III
Video Card: XFX GeForce 9800+ Black Edition
Memory: PCI Turbo 2x1GB DDRII 667
HDD: Western Digital Caviar 1200 120GB IDE
OS: XP Home Edition SP2
Case: Ahanix Platinum XP with 90 mm fans
All stock settings no overclock.
The temp on the CPU on Idle is 33 degrees as Everest reports so the CPU can't be overclocking upon initial boot. Now what I've noticed is this power on-off-on issue only happens when I switch off the power strip the computer is plugged in. If I Ieave the strip on, it just powers on the first time everytime with no problems of the "shutting down then turning on" as mentioned. It seems if the current is cut from the power supply by switching off the strip, this problem occurs but if left on there's no problem. Is this a PS issue or something in the BIOS? I'm a compulsive dude, I know most of you guys leave the power strip on but I'm always afraid of catching fire so I always turn it off. However this powering issue didn't happen on my old ASRock 775 DualVSTA mobo.
Message edited by Duetto on 08-12-2009 at 10:25:50 AM
Sponsored Links
What do you mean by "it turns off instantly? No lights nor fan spinning?
Reply to masterjaw
- 0 +
It turns on for a split second (fans spin and lights on for a split second) then turns off: no lights or fan spinning for two seconds, then turns on again and power stays on this time.
Message edited by Duetto on 08-12-2009 at 10:31:34 AM
Reply to Duetto
Try to check for loose connections to the mobo.
Reply to masterjaw
- 0 +
Tried that one. Checked all the headers and they're all planted firm. I'm thinking of getting a higher wattage PS if the one I have might be struggling. I want to hear all your opinions though.
Reply to Duetto
I remember my P35 board doing that but only when I changed a setting for overclock. I would check your bios settings to make sure they are @ default values if not intending to overclock. There could be a setting that is causing your system to not boot properly and making it go into default but until you change the setting and save it anytime you shut down your system it will read the incorrect setting.
------------------------------ Antec 900, 750w Corsair, Biostar T-force TA790gx 128m, Phenom II 940 @3.6ghz 8gb G-Skill DDR2 1000, 750gb F1 Samasung, 1tb Seagate ES.2, Sapphire 4870 1gb
Reply to logainofhades
- 0 +
Reset your CMOS to defaults.
Reply to jtt283
Relax...there are alot of mobos that do this when first powered.
I believe its a PSU check of some sort before the system starts up.
My gigabyte does this too if I pull the plug on it.
Why do you shut the power strip off in the first place? I only do that if I'm going away for some time....
Anyway hope this helps....JQ
------------------------------ Intel C2D E8400 @3.0GHZ, Gigabyte GA-EP45-UD3L motherboard, 4GB OCZ vista platinum DDR2-1066 , Seagate320GBsataII 16MB HDD, BFG GTS250oc 512 GDDR3...3Dvision glasses and samsung 120HZ screen.
Reply to johnnyq1233
Ahh I missed the power strip part. Yea that is pretty normal and I think both my AMD and Intel rigs do that when all the power has been removed from the system like that.
- 0 +
Some of my computers have done that; some haven't. I suspect that it's a function of some PSU's.
I you do not have any other bad symptoms, I would not worry about it.
Reply to jsc
- 0 +
Thanks for the input guys. Glad to know it's not only happening to me =)
Reply to Duetto
- 0 +
as has been said, its very typical when power is reapplied to the PSU
Reply to uh_no
There are 937 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
