Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Remote Desktop printing problem
Forum Windows XP : General Discussion Remote Desktop printing problem
Hello,
I am trying to print from the remote machine to a printer on my local machine using RD. The printer is an HP Officejet 5610 connected via USB which from what I've read may be part of the problem.
Here's what I've done so far:
At first it wouldn't even see my printer on the remote machine, so I followed some instructions to do with printer pooling ports.. now I have the printer visible on the remote machine. When I try and send a test page it leaves the remote machine and appears in the HP printer queue on the local machine.. so far so good. But then it just sits there, with the status saying "printing" but the printing doesn't start.
Also the size is stuck on 571bytes/278kb. I believe the print job name should have a suffix like "from remote machine" or something like that but it just says "no document name". It seems like I am close to making it work, but not sure how to solve this?
cheers
Reply to jamboh77
Yup, sounds close to me too. Check that you have "File and Printer sharing" turned on at the host machine. Check firewall isn't blocking printer.
Check printer driver is installed in remote machine so it can send data properly to the printer.
If you're going to tell someone where to go, supply a link to get there.
Reply to tigsounds
There are 2103 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 18 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
