Tom's Hardware > Forum > Homebuilt Systems > New System Build > Does my PSU have enough cables for all my parts
Forum Homebuilt Systems : New System Build - Does my PSU have enough cables for all my parts
Does this PSU have all of the cables for my parts and including the case fans. If not what do i do?
PSU-http://www.ebuyer.com/product/124927
Graphics-http://www.ebuyer.com/product/161967
HDD-http://www.ebuyer.com/product/124735
Case-http://www.ebuyer.com/product/134798/show_product_reviews?offset=30&review_type=both&review_order_by=RUF
Optical-http://www.ebuyer.com/product/96712/show_product_reviews
I would apreciate the help
Sponsored Links
Regardless of whether or not it has the right connectors, you should avoid that PSU. It is cheap for a reason. Look at a Corsair 550vx or 650tx if you will add some more HDD's later.
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
I completely agree with xthekidx
------------------------------ http://www.boostingmoney.com
Reply to Tech-Boy
After all the advice you got in your other thread, why would you still choose a crap PSU? If you want a higher wattage PSU you will need to increase your budget.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | 2x GTX260 216
Reply to theAnimal
There are 744 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
