Question about hard drive connections on the rear of device..
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145304
On the back of the drive there is the SATA Power and Data connections, but there is also a small 2 pin connections right next to it. What is this 2 pin connection (kinda shaped like an RJ port) for?
6 answers Last reply
More about question hard drive connections rear device
  1. I really don't know what kind of connection it is, but I wouldn't worry about it.
  2. So itll work with just the 2 SATA cables you think?
  3. One of the PCB connections is SATA power, and the other is SATA data. Plug in a SATA cable to the data one, and a power connector into the power one (they can't get mixed up), and there is no reason that it shouldn't work.
  4. I know.. I've just never seen a HDD that had the bonus jack. that's what I'm trying to find out about :D
  5. Probably jumpers for forcing SATA1 speed (some SATA1 controllers cannot work with SATA2 HDD)
  6. Yeah, but the connector didn't look like the type used for jumpering.
Hard Drives Devices Storage Product
