Tom's Hardware > Forum > Motherboards & Memory > Foxconn > Foxconn g31mxp front panel Audio not work
Forum Motherboards & Memory : Foxconn - Foxconn g31mxp front panel Audio not work
how to connect the Front panel in to F_AUDIO port
Sponsored Links
Go here to access information on your motherboard. Included there are links to the manual, which describes the F_Audio port pins. You have to compare the pins there with those on your unnamed case and adapt them if needed.
http://www.foxconnchannel.com/prod [...] -us0000416
This is the link directly to the manual:
http://www.foxconnsupport.com/down [...] d%20Manual
The pins are described on page 15 of your manual
Message edited by mongox on 10-28-2009 at 09:52:27 AM
------------------------------ Gigabyte MA785GM-US2H, AMD Phenom II x2 550 BE (4 cores@3.6GHz), G.Skill 2x2GB DDR2 1066 (820@CL4), Scythe Katana3, Hec 585W, Samsung 2232BW+, WD Caviar Black 1TB SATA, Sea 500GB USB, 12 IDE HDs w/Masscool IDE-SATA Convertors, Ugly Old Case, Win XP 32bit
Reply to mongox
Thanks mongox,But i cant compare that pin configuration with front panel board.because it is no named,it's wire ends marked as FR_R, FR_L, RR_R, RR_L, MIC POWER, GND, MIC_IN.
Then how connect them.
are there any jumper setings related to F_AUDIO ?
plz help me further.
Message edited by gmadushanka on 10-29-2009 at 05:00:00 AM
Reply to gmadushanka
Thanks zipzoomflyhigh,But i cant compare that pin configuration with front panel board.because it is no named,it's wire ends marked as FR_R, FR_L, RR_R, RR_L, MIC POWER, GND, MIC_IN.
Then how connect them.plz help me further.
It's very likely that if the front panel is designed for HD audio - and some are designed for AC'97 - then it will plug right into the 10pin header you have.
Does it only have nine wires? Is the empty place over pin8? If so, you're likely just fine plugging it in.
Here are two Front Audio plugs, despite the different names, they are the same. Yours is the first one listed.
http://home.roadrunner.com/~expertpc/toms/f_audio1.jpghttp://home.roadrunner.com/~expertpc/toms/f_audio2.jpg
Reply to mongox
From this I gather that
MIC2_L is the same as PORT1_L
SENSE_SEND is same as FAUDIO_JD
etc...
I really think these things are standard - if the front panel is HD Audio. Plug it in and see if it works.
Reply to mongox
Note the following. It shows a HD Audio pinout compared to a AC'97 pinout. Sounds like your front panel of the case is using AC'97. Your motherboard only supports the newer HD_Audio.
I do not know if a front panel wiring from the case designed for AC'97 will work properly with HD Audio. Your case may also include two different wiring harnesses.
http://home.roadrunner.com/~expertpc/toms/f_audio.jpg
Notice how closely what you describe fits the AC'97 pins!
Note the above graphic and instructions are NOT about your motherboard.
Message edited by mongox on 10-29-2009 at 06:31:55 AM
Reply to mongox
thanks mongox,i think my mboard not support that chassis audio port.my mboard manual noticed that F_AUDIO is HD standard.then i cant set three GND wires to pin 2,6 and 10.chasis has only one GND.
There are 1185 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
