XPS M1210, will this drive work for a replacement?
I have a Dell XPS M1210 and I decided to upgrade it a little bit.
Anyways, battery and memory are the two things I am upgrading for sure, cuz battery is completely dead, and memory is only 55$ upgrade.
But I am positive that Sata, Sata 1.5 and Sata 150 are all the same thing, and Dell has a SATA-150 as a replacement on their website, but I assume this WD Sata 1.5gb HD will work?
So on Newegg they have a Western Digital Scorpio Blue for 45$,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136799
I was wondering if this would work in my laptop? Obviously i will need windows and all that yoddaling.
but I want to know if it will work as far as compatible wise.
Thanks!
1 answer Last reply
More about m1210 drive work replacement
  1. hardware wise it is compatible the last question is if your BIOS will support it.
    check for the latest BIOS
Hard Drives Battery Dell Studio Xps Memory Western Digital SATA Storage Product
