Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Biostar Motherboard and GTX 280 Problem
Forum Graphic & Displays : Graphics Cards - Biostar Motherboard and GTX 280 Problem
Now I'm not new to this but try as I might I can't get my BFG GTX 280 OC2 to work with my Biostar TA790GX A2+. I get the card to power up with the green lights showing but my motherboard has 2 LEDS to show if the card is owrking correctly and I can only get one to light up. Any ideas ?
Sponsored Links
Just a suggestion, but if the card works in another MB, perhaps go in to BIOS and disable the onboard graphics and be sure the PCIE is set as first device. Check BIOS options onboard video ATI 3300 in the MB manual onboard video.
------------------------------ "To better understand why you need a personal computer, let's take a look at the pathetic mess you call your life."
Reply to badge
Cheers mate.
Have turned off the onboard graphics but still can't get it working. I'm thinking it may have something to do with the BIOS setting for 'GPP Slots Power Limit' but can't find any information on what I should set it to. I don't feel comfortable with experimenting with this, getting it wrong and recking either my motherboard or card. I've asked Biostar but they have not responded to my 2 emails.
Reply to daveyt69
Is there a setting for 'PCIE as primary video' or something similiar. ASUS American Megatrends (AM) BIOS is fairly clear about this sort of issue. Have you tried simply defaulting the BIOS. Reinstalling the card? Maybe BIOS is not picking the card up in the I/O correctly.
Reply to badge
MB product page. If you haven't already, download the MB manual and look at the BIOS section for the video selection/settings.
http://www.biostar.com.tw/app/en-u [...] p?S_ID=374
Reply to badge
Interesting.. I see were you are going. However the motherboards BIOS is showing this: PCI-GFX0-GPP-IGFX (Default) which makes me think that the PCI express is the default.
I've been reading the manual a bit but it is as clear as mud as to what the correct settings should be. I may have to experiment a bit with the wattages accross the PCI express slots.
Reply to daveyt69
Have you tried a different video card in the Biostar MB? Is it just the 280 that won't power up?
Reply to badge
My old 6800GT and my mates 8800GTS all work fine. The card itself gets the green lights to show that is powering up but the motherboard on has one of the 2 LEDS lit. The Motherboard manual says this is a VGA error.
Reply to daveyt69
If other cards work fine I would look at the 280 possibly having a problem or an inadequate PSU. Also, if you have a DVI to VGA adapter, try plugging in to the VGA side of the monitor iwith the adapter. Use the VGA input of the monitor. Not the DVI input of the monitor.
Message edited by badge on 05-30-2009 at 07:20:35 PM
Reply to badge
Thanks for that i'll give it a shot.
Reply to daveyt69
Okay tried a different monitor both VGA and DVI and no luck.
I'm begging to think I need a new motherboard. I've a 5200+ right now but will want to update later on to a quad core phenom (probably). Any ideas for about £80.00 that will cover both the gaphics card and the processor upgrade.
Sorry for the scatterbrained post but i'm at my wits end with this one.
Reply to daveyt69
Do you have the aux molex plugged into the mobo?
Reply to mousemonkey
Yep got that little sucker installed. CPUID states the master slot is running at x16 so I'm a bit stuck.
Reply to daveyt69
The only other thing I can think of is that as the mobo has onboard graphics then PCI-GFX0-GPP-IGFX (Default) refers to the onboard and not the PCIe slot (which would make sense really).
Message edited by mousemonkey on 06-01-2009 at 09:03:04 PM
Thanks i'll try messing about with that setting.
Reply to daveyt69
There are 1307 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
