HDD problem with HD Tune screenshots
Last response: in Storage
I had this HDD as my primary OS HDD with Win7 64bit, intitally running on IDE mode. Then I switched to AHCI mode.
The benchmarks are weird, don't understand why is the performance that bad. Now on Microsoft AHCI driver as what the forums recommended not to use AMD SATA/AHCI Drivers.
I experienced slow booting and shutdown time with AMD AHCI driver 1.2.1.269.
Below are HD Tune screenshots done without any running programs and without any background programs that write/read data even disabled AV protection.
The specs are as follows.
HDD: Seagate 250GB 7200.10 SATA2 ST3250620AS
Sata cable: Silverstone CP04 SATA Cable
Mobo: 939A790GMH
Northbridge: AMD 790GX
Southbridge: AMD SB750
On IDE mode
On AHCI mode AMD AHCI driver 1.2.0.125 Test #1
On AHCI mode AMD AHCI driver 1.2.0.125 Test #2
On AHCI mode AMD AHCI driver 1.2.1.269
Standard AHCI 1.0 Serial ATA Controller
Ask the community
