Cpu cooler to fit in my case without hitting ram or side fan
I am trying to figure out which cpu cooler will fit in my case without hitting ram or side fan. I installed the stock cooler for now but want to upgrade the cooler ASAP so I can start rendering the video which I know will put a lot of strain on CPU. My specs are listed below. Any help would be great. I plan on turning on hyperthreading.
I don't think this will require overclocking.
The components are:
Motherboard: Asus P7P55D-E Pro
CPU: Intel i7-870
Memory: G.Skill Ripjaws 8GB (4gb x 2) DDR3 1333 (F3-10666CL9D-*GBRL)
Case: Apevia X-Plorer2 (pink/black)
Video Card: HIS ICEQ Radeon H567Q1GD HD5670 RT 1GB
PSU: Corsair 650HX modular
HD: Western Digital Caviar Black 750GB 7200RPM
also have a WD cavier green 500gb used for storage as well as several external HD of various sizes
Monitor: HP vs17 LCD
Modem: HIRO data fax 56k H50006 PCI card
Optical Drive: lg lightscribe cd/dvd burner
SOFTWARE:
OS: Windows 7 pro 64bit system builders
Photoshop CS5 extended
Corel/Ulead Video Studio 11.5 plus (will be upgrading to X2 if 11.5 doesn't work with win7 64bit)
I do a very large amount of photo editing (have canon digital rebel and shoot in raw format). I digital scrapbook and have had files exceed 1gb.
I also do video editing of home videos converting mini dv tapes (.avi) to dvd, as well as dvd slideshows (this is your life type things).
I am coming from dell dimension e310 pentium ht and windows xp pro 32 bit, where rendering a 2 hour video took almost 24 hours.
4 answers Last reply
More about cooler case hitting side
  1. Your options are limited since your case is only 7.25" wide and includes a 200mm side fan which further reduces the width.
    Also depends on how much you're willing to spend since some coolers cost more then a good case.
    Noctua NH-C12P SE14 140mm SSO CPU Cooler
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835608019
    Noctua NH-U9B SE2 92mm SSO CPU Cooler
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835608016
    COOLER MASTER Intel Core i5 compatible GeminII S
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103046
    XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233081
  2. Thanks for giving me some options. I have been looking at all the different coolers for days, but am just a little overwelmed by all the choices and I just want to make sure it will fit on the motherboard without interferring with all 4 of the ram slots (I do plan on adding 2 more sticks of G.Skills ripjaws to up the total to 16mb if I see the need to do so) and also in the case. I measured and get a little over 5" that I have to play with as far as distance from MB to case fan on side.
    I had been looking at the different zalman coolers, but just couldn't figure out if they would fit.
  3. I think I am going to pick one of the noctua coolers you suggested. I just have decide which one, just wish they weren't so blah looking. Thanks again for the help.
  4. I'd go with the Noctua...Those fans alone are expensive and high quality.
Heatsinks Cooling CPUs Overclocking Product
