I recently had a water cooling disaster which fried my BFG 680i board and I'm looking to get a new mobo that will be compatible with my x6800 cpu. I also would like the option of using SLI so that limits me to nVidia chipsets.
I am currently water cooling my CPU, northbridge, southbridge, and gpu with the associated swiftech water blocks and a 2x120mm fan radiator.
I want to OC as much as possible.
My question is:
Does the Fusion water cooling system built into the Striker II extreme perform well? Would my swiftech waterblocks outperform the Fusion system?
I just bought the entire water cooling setup and I would hate to waste the chipset water blocks if they work better than the Fusion water block system. If i removed the Fusion heatpipes from the mobo I'm worried it would lead to cooling problems elsewhere on the board, not to mention void my warranty.
I'm using 3/8inch inner diameter tubing on a single loop: reservoir -> pump -> radiator -> cpu -> nb -> sb -> gpu -> reservoir
Any help with this would be appreciated, and I don't have my heart set on this mobo so any suggestions there would be welcomed too!
No I am not doing SLI now, but I might like to in the future to get a few extra years out of my system without upgrading to a new socket type (and presumably having to buy all new components).
Before the accident I didn't have the gpu in the loop, I was adding it when I loosened a barb allowing liquid to discretely leak onto the southbridge. I figured I may need to add another 120 rad after installing the GPU, but was going to see how it went since this is my first water cooling attempt. I have a silverstone TJ09 chassis with the 220 rad installed within the chassis under the top-side exhaust. I might have added the 120 into the mid-chassis fan as was done on this website during a system builder marathon.
Am I way off base here? Is waiting to upgrade to SLI not cost effective in the long run? Should I forget the nvidia 7 series and go with an intel chipset? Is removing the heatpipe assembly from the striker II and replacing it with my swiftech waterblocks an option?
I know thats a lot of questions but thanks for any help
I guess if I have all the cooling components already getting something like the striker II or rampage with a heatpipe jungle is a waste. Is there a good 790i board or even an intel chipset board without a maze of useless heatpipes?
1. The 8800GTX is already an old card. Don't bother doing SLI on it. A modern single slot card like the 5850/5870 will pwn that 8800GTX.
2. Get a single PCIe x16 slot P45 board like the UD3L and it should be good. Swap out for a better single slot card (ie 5850/nVidia 3xx when released) down the road if you need to.
3. No point in trying to extend the life of LGA775 and/or GPU. They are both old tech now. The motherboard/CPU will however last longer than the GPU assuming no bottleneck by CPU.
PS: Make good backups of what ever in that 1TB drive. The 750GB+ HDDs have quite a high failure rate.
Message edited by shadow703793 on 10-30-2009 at 01:37:29 AM
Ok so probably better not to spend too much trying to salvage an aging system.
I'm going to go with a P45 system but I would really like one with an eSATA port and great OC abilities.
That gigabyte board has no eSATA port, and as far as I can tell none of the Asus p45 boards without that obnoxious heatpipe jungle have one either. The P5Q doesn't have one, and the P5Q deluxe/premium have them as well as too many heatpipes!
I'm going to keep looking, but thanks for the feedback it really helped get me on track.
The gigabyte board is more friendly in terms of heat pipes, but I'm concerned about the clearance of the PCIe slot and the southbridge. If I put a tall waterblock (MCW30) on there a large graphics card like my 8800 might not fit.
The asus board has great reviews for OC'ing but the heatpipes for the northbridge extend to the area around the CPU making life a little more difficult for me. Think I could get away with some cheap ramsinks right there? Or maybe just some well placed airflow? If I'm correct that heatsink by the CPU cools the components which power the cpu? If so I don't want to destabilize the board by pulling off that heatsink.
