Tom's Hardware > Forum > CPU & Components > CPUs > AMD Phenom II X4 940 Performance rating problem :S
Forum CPU & Components : CPUs - AMD Phenom II X4 940 Performance rating problem :S
Hi guyz..I just want to ask about something i don't understand.. :)
.I have an AMD Phenom II x4 940 processor (running @ 3.38GHZ)..I think the normal speed i got it is [ 4 x 3.38 GH = 13.52 GHZ or near it] and correct me if i'm wrong..when i have tested my system componets by a tool called www.systemrequirementslab.com , i use it to test my pc is able to run a specific game or not..it's useful btw..I found it told me that my processor performance rated at " 8.61 GHZ" !!!! :fou: when i run the test on GRID racing game..and games like it..
Is it a normal performance rating for my processor or there's something wrong ??
I have
Windows Vista Ultimate x64 SP2
Nvidia Geforce 8200 motherboard
4GB of DDR 2 ram
8600 GT with 512 DDR2 dedicated graphics memory on it
note: the motherboard supports processor till 95 W .. this processor is 125 W but it runs fine :) is that is the problem or what?
PLZ HELP GUYZ...THX
Sponsored Links
I wouldn't worry about that. You should be fine.
------------------------------ Phenom II X2 unlocked to four cores @ 3.8gHz,1.45V. 4GB DDR3-1600 Gigabyte 785g ATi Radeon HD4870 1GB
Run Folding@Home! Support Toms Hardware Guide, Team 40051!
CPU Buyer's Guide
Reply to smithereen
You don't multiply the core speed by number of cores, it doesn't work that way.
I also know of that website, it's a bit of a joke when it comes to those ratings, I think it gives it a rating based on a P4's performance.
Reply to loneninja
thx Loneninja for your answer..but can u just explain more ??
Reply to makook_99
What do you need explained? The website extrapolates the PR rating used by Athlons with other CPUs, as the "CPU Speed" requirement listed in game requirements is still usually for a Pentium IV CPU. Also, I think it only uses up to two cores to calculate the rating; you're CPU would provide about that gaming performance of an 8.61gHz Pentium IV.
CPU Buyer's Guide
Reply to smithereen
At a guess I would say it only tests on two of your cores as most games are optimized for either single or dual-core.
Reply to Devastator_uk
i find yougamer.com have better ratings
Reply to obsidian86
There are 530 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
