Tom's Hardware > Forum > Homebuilt Systems > New System Build > I7 920 build need help
Forum Homebuilt Systems : New System Build - I7 920 build need help
Right now i got an amd pc, so im going to build a i7 920, but i need some suggestions for motherboards
my price limit is about 1200$
All i really need is, i7 920, motherboard, ddr3 ram,
i already have a 9800gtx+, and i want to get a second one, so i need a psu with 4 pci-e 6 pin connectors
i need to know a psu that can support the i7, motherboard, 2x9800gtx+ 500G HDD, ddr3 ram
suggestions please
Sponsored Links
EVGA motherboard is excellent for SLI:
http://www.newegg.com/Product/Prod [...] 6813188046
ASUS p6T is also a good choice and cheaper:
http://www.newegg.com/Product/Prod [...] 6813131359
Corsair TX 650 or 750 are both great PSU's:
http://www.newegg.com/Product/Prod [...] 6817139005
http://www.newegg.com/Product/Prod [...] 6817139006
Use a PSU calculator to find out how much juice you will need - and remember to include overclocking if you plan on it:
http://extreme.outervision.com/psucalculatorlite.jsp
Reply to nerrawg
I calculated the PSU, its gunna be 755w minimum
so i think an 850 would work, any suggestions?
So heres the start, i think ill go with this motherboard
evga e758
i7 920
http://www.newegg.com/Product/Prod [...] 6819115202
Message edited by billiam111 on 05-11-2009 at 02:19:43 AM
Reply to billiam111
There are 1058 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
