Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Radeon 4770- newbie could use some help...
Forum Graphic & Displays : Graphics Cards - Radeon 4770- newbie could use some help...
This is kindav long, but I tried to add as much detail as possible in order to recieve an accurate solution to the problem. If anyone could provide a solution then that would be absolutely amazing!
I got a new graphics card yesterday (Saphire Radeon 4770), and after I got it in the case and got the drivers installed (from the disk), just a few problems started to occur once I tried to play games. Originally the moniter would just shut down and go into ''power saving mode'', and I would be forced to restart the pc. After messing with a bunch of settings, the games would shut down and I would get an error message saying ''VPU Recover has reset your graphics accelerator as it was no longer responding to graphics driver commands'' with the options to send an error report or not to under it.
This is the first time I have changed or added hardware to my pc, so I really have no idea what to do. I did go to ATI's website to download the drivers, but that didnt seem to help. What I did download was the Full Catalyst Control Center Suite, since besid it it said to download that if you need both the drivers and ccc.
(http://game.amd.com/us-en/drivers_catalyst.aspx)
When I was installing the card, It came with a wire (power wire I think)
and an extra adapter type thing. Since we did figure out that it was a
power wire, but couldnt figure out where one end of it went, we just
put one of the extra power wires that was laying around in the pc
onto the card. The one we plugged in was the same kind that came in
the box, but the other side just went straight to the psu. Could this
have anything to do with the problem?
While I was still having the ''going into power saving mode'' problem,
someone else took a shot at fixing it. I think he did download the
drivers again, could this of had any effect on the problem?
Like I mentioned, this is my first hardware change. And with all these
problems not letting me play games, I'm getting really annoyed at
all of it even though it's probably something really stupid I'm missing.
A solution would be extremely appreciated!
Sponsored Links
Did you delete the old graphics cards drivers before trying to install the new card?
Reply to willi1615
What are your system specifications? Original video card before the 4770?
Reply to AKM880
Weird, I didn't think they would even have the pci-e connector but apparently they do.
The little wire that came with it was a molex to 6 pin pci-e converter. You didn't do anything wrong there.
Try out Driver Sweeper and re-install your drivers.
Message edited by Dustpuppy on 05-31-2009 at 10:27:23 AM
Reply to Dustpuppy
umm.. maybe he has a bad card but if that is the case i would return it
and get a http://www.newegg.com/Product/Prod [...] 6814102824 for $99.99 4850!
4770 for $99.99 is silly and not priced right it should be changed to like $69.99
Message quoted 1 times
Message edited by adrianmk2 on 05-31-2009 at 04:57:47 PM
Reply to adrianmk2
There's no reason for a 4850 when the 4770 matches it. 4770 is probably the best budget card on the market today
------------------------------ Core I7 920 D0 @ 4.2Ghz
MSI X58 Pro-E
32GB SSD, WD Blacks In R0
Sapphire HD 5870's In XFire
Reply to PsychoSaysDie
4850 performs slightly better than the 4770 non OCed. What they need to do is to lower the price of the 4830
------------------------------ i7 920, E5300
GTX260, HD4870, HD4830
Reply to Bluescreendeath
No I didn't. Could this be a problem?
And my old card was a Nvidia Geforce 6150LE.
Reply to cypher220
Is the 6150LE integrated graphics? If so you may need to enter your motherboards bios and make sure pci-e is set as your primary graphics adapter. You may be able to disable your on board graphics in the bios as well, so look around for that option.
Reply to Dustpuppy
Whats your PSU? And you may need to change it to the PCIe slot instead of onboard GPU like dustpuppy said.
Reply to AKM880
We need the specs first be4 we go RmA this card. for all that i know its his psu being to weak thus making the pc go to a stop thus not sending any video feed. Wich makes the monitor believe the pc is shutting down. so that could ecplain a bunch of things
Reply to ill b ben
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
