but it requires2 6 pin connectors. first off I looked in my case and found only one 4 pin. is their like a splitter to goto two 6 pins? because i dont know what todo.
I think I have an extra 4 pin in my case but its way in the front and theirs no way it would be able to reach the gfx card. help
it says 2 6 pin connectors but I couldnt find them. would I already be using them? (im only running an 8500GT) or are they just tucked away somewhere in my case?
the PSU from best buy will def power the graphics card and yes that PSU has 2 six pin power connectors i beleive
Uber
------------------------------“Not only does God play dice, but... he sometimes throws them where they cannot be seen.” -Stephen Hawking
Reply to UberGenocide
They are tucked away in the case somewhere, unless they have been cut off!
Obviously, go looking for them with the computer turned off and the mains lead removed.
------------------------------Peace cannot be kept by force, it can only be achieved by understanding: Eienstien
Reply to coozie7
