New drive hangs when formating at 54%... faulty drive?
I'm formatting a new 2 TB Western Digital hard drive and for some reason it hangs at 54%. Is this a case of a bad drive? Or is it inconclusive at this point?
4 answers Last reply
More about drive hangs formating faulty drive
  1. How long does it hang for? I've had drives that stop as certain places for 20+ minutes and then eventually works out what it's doing and continues. If it hangs for over a couple hours on a slow computer or 30 minutes on a fast computer then I would lean towards a failing drive.
  2. What OS are you formatting it under?
  3. Thanks for the answer guys. My problem has been resolved. Basically what happened was that I was trying to format the drive, however I was doing it under Windows Vista 32-bit, which apparently doesn't recognize a drive that big unless you're doing it under a 64-bit operating system like Windows 7. I had Windows 7 64-bit ready to go and under that I had no problems.
Hard Drives Western Digital Formatting Storage
