SO THIS IS WHAT I PICKED! help me pick a motherboard and make sure these pieces will perfectly fit and work, i have 700 pluss tax and shipping for this project, recomend me some better pieces and this is not a gaming computer so dont give me a expensive video card, i just want a decent one that can run some small video games such as gta san andreas. ill be using this computer for video editing, photoshop and stuff like that. and also tell me if i have to buy a original os to make it run or if i can just use this win xp ice that i have. i dont need a monitor, ill be using a 22 inch hdtv. thanksss! so i have like 100 bucks for the mother board make sure the video card is included
The build is off to a decent start. That PSU is OK, but this one would also power that system and save you a little money along the way.
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817139008 $49.99 - $10 MIR + an extra 20% off using promo code "Maypsu20".
You don't need DDR2 1066 RAM with a Core 2 CPU. This RAM would work work great with that system:
That is a good basic build. the game you want to play though is not coded to run on multiple cores, you will get more benefit from one fast core than four slower ones. If that is less important than your video editing needs then your current configuration is good.
Why do you want that one? The integrated graphics on it are not very good, your game will be choppy, and it is made to accomodate extra video cards, which you don't want so you are paying for features that you don't need. The build that Shortstuff made is much better suited for your needs.
Total with shipping: $712.44, and then there is a $20 rebate. If you want to cut the price down the price, you can go with the 400cx that shortstuff mentioned, and use that windows xp license you have (im not sure what you mean by ice) or use Windows 7 RC which is free for download right now.
thats cool but do i really need an original os cd couse i have a cracked one will it work>??
LOL, you don't need the Xigmatek bracket unless you're getting a Xigmatek cooler. If you do want a Xigmatek cooler, I would ditch the bracket you have listed and get this cooler instead:
Be sure to read the stickies at the top of the forums. It's also very important to read the motherboard owners manual. A google search for "how to build your own computer" should give you more than enough reading material and videos to keep you busy.
