Hi friends, I would like to change my PC Case to reduce the fans noise.
I currently have:
Zalman CNPS9700NT CPU Fan
Asus P5N-T-DX Motherboard
Thermaltake Armor VA8000BWS
OCZ 700W Gamer XStream SLI (OCZ700GXSSLI)
Intel Q9450 2.66Ghz
I try to reduce the fan speeds but the lowest i can get is 2500 RPM for the CPU.
My Zalman cpu fan make WAY too much noise.
I need to find a new PC case that will cut by half my pc noise.
I second getting a new CPU cooler. Look for cases made of steel or really thick aluminum. Heavier cases don't resonate noise as much as light wieght cases do. The cosmos 1000 is the quietest case I've used personally. The p182 is way to cramped and can be a problem with some PSUs.
Edit: on second thought, look how the Zalman 9700 at 1250 rpm is just as quiet as the others. For example it got the same dB as my own Scythe Ninja, and I can tell you that one is very quiet. Can you just reduce the rpm for your cooler instead of replacing it? You can use a free download called Speedfan for that.
Message edited by aevm on 05-12-2009 at 06:09:59 PM
i cant reduce more the RPM of my fan because the Motherboard do not allow me to go slower
I setup my Asus P5N-T-DX fan speed to to lowest option which is silent. and it still run at 2500. at normal speed it runs at 2800 rpm.
there is a significant diffirent on the sounds by just 300 lower than normal. so if i could only reach 2000 RPM. i think my cpu will still be in good shape and ALOT of noise will be reduce too. but i cant found how.
i try using the speedfan. but cant find the option to set the fan speed...
I have the Zalman 9700 NT...and it does get a little loud when its running high. I will also tell you its a lot quieter than other CPU coolers...it could actually be louder but its not ^_^. Mine keeps the CPU @ 38°C on idle..and 50°C playing crysis...Even then its running at about 1500RPMs and i can't hear it. Maybe its the case too...but i can hear the 8800GT running at 80% fan speed...very loud.
I would like to buy a water cooling system for my CPU and single Video card or possibly two video cards.
My system temp is getting very high when playing games.
Motherboard: hover 55degrees
CPU: hover 70 degrees after 30mins
i have a full tower with 4 fans on it. one on top 90mm, in front 120mm, and back 120mm. near the power supply 90mm plus fan of the power supply.
I currently have: Zalman CNPS9700NT CPU Fan
Thermaltake Armor VA8000BWS full tower
Intel Q9450 2.66Ghz (not overclocked)
I need solution to fix my temp
thanks all!!
The reason you can't get the Zalman CPU cooler to run slower/quieter might be because its running too hot.
Are you sure the CPU cooler is installed correctly?
I agree. The fan won't slow down when the CPU is overheating. I would pull off the cooler, clean off the thermal paste, install fresh thermal paste, and re-install the HSF. You shouldn't be getting anywhere near 70C on a non-overclocked CPU with that Zalman HSF.
One other thought. The CPU fan is plugged into the CPU_FAN header and not a SYS_FAN header, right?
