Tom's Hardware > Forum > CPU & Components > CPUs > Cpu cooler fan speed
Forum CPU & Components : CPUs - Cpu cooler fan speed
hey guys
i bought a coolermaster v8 and ive replaced the fan with thermaltake smart fan. BUt it always runs at 2700rpm and its loud!
how do i change the speed to it will only increase depending on the temp. it has 3 different speed pwm.
this is the fan im using now http://www.thermaltake.com.au/Prod [...] anLED.aspx
Sponsored Links
it also has a fan speed controller to put it in one of the card slots. but that controller doesnt seem to slow down the fan speed at all.
Reply to kromesta
Application for PC case and CPU fan
Three sizes available 8.9.12CM
3 BLUE LED fan
Smart LED Fan (3 functions in 1) :
1. Full speed when jumper on
2. Temperature control : Fan speed varies according to the temp detected by the sensor
3. Manual control : Adjust fan speed manually
it says at number 1. full speed when jumper is on. how do i disable this so i can use the other functions
Reply to kromesta
nevermind guys. ive solved the problem. fan speed controller wasnt plugged in properly.
Reply to kromesta
There are 572 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
  • 01:00 ayeohx won the Freshman badge
