Tom's Hardware > Forum > Motherboards & Memory > Memory > Triple Channel Problem [HELP]
Forum Motherboards & Memory : Memory - Triple Channel Problem [HELP]
I have 8 GB geIL ram installed onto my computer yet only 4GB is detected.
I do have windows 7 64bit
http://valid.canardpc.com/show_oc.php?id=798214 <--- info
also i think the problem is that is shows its dual channel on CPU-Z i dont know how to change it to trip
i've checked my motherboard bios i cant find anything.
these are my computer specs if they help in any way
Motherboard: ASUS P6T DELUXE V2
Graphics: ATi 4890 HD
RAM: 8GB geIL 1600MHz
HDD: SSD 60GB, 1TB
CPU: Core i7 920
OS: Windows 7 64bit
anyother info you need please let me know
thank you
Sponsored Links
You don't need to change anything; with 4 out of 6 slots populated, you can't run in tripple channel mode, and the performance hit is small. If you want tripple channel mode, then fill up the last 2 slots, but I don't think it's worth the money with memory prices so high. And according to the diagram on the left, all 8 gb is being detected.
Message edited by o1die on 10-30-2009 at 07:14:13 PM
Reply to o1die
I would recommend getting the 2 more sticks when you can get a buy - memory is marked down on sale from time to time = keep checking tigerdirect.com - I think the best service and price on the net.
Reply to silverron
Yes its detected but not on my windows so its not in use only 4GB is.
So i have to fill up the other slots for it to work? >.>
Reply to reconic
@reconic
TRIPLE channel is called triple because you have to install the ram sticks by 3. So either go with 3 sticks or 6 sticks.
Reply to sky03
I have tried it with 3 sticks it doesn't work i have 4 sticks in atm 2gb each
Reply to reconic
There are 475 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
