G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I have 3 physical drives in my machine. Cboot) Ddata)
EData) I used partition magic to carve out about 30 megs
each off D: and E: and made a stripe drive (S using XP
software of 60 megs. All of this worked fine.
Problem is - the page file won't stay on S:. I set it up
with all drives but S: with "No Paging File" set and S:\
with 1024 MB set. It OK's through all that and after the
reboot the page file is on C:\! Settings are exacty what I
set them as (on S?
What is going on?
set them as (on S?
What is going on?
