Tom's Hardware > Forum > Homebuilt Systems > New System Build > New i7 build advice for Audio PC
Forum Homebuilt Systems : New System Build - New i7 build advice for Audio PC
APPROXIMATE PURCHASE DATE: ASAP
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Streaming audio, nothing else but has to be rock solid
PARTS NOT REQUIRED: High-end video card, monitor, soundcard, keyboard, mouse
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: i7 920, 12 GB RAM (possibility to upgrade to 24 would be nice, speed isn't really important), 2 dedicated SATA 7200 drives for sample streaming, Gigabit ethernet, vanilla DVD drive, 64 bit OS
OVERCLOCKING: No
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: Not important
I'm an audio professional who works on a mac but I'm finding a few bottlenecks even on a pretty decked out Mac pro so I was thinking about offloading one of my main sample libraries that is cross platform and a huge resource pig to a dedicated PC. I'm pretty comfortable digging around the inside of a computer case and doing RAM installs, drive replacements, etc. but I'm by no means an expert. I'm wondering if anyone has a general idea on the price tag and degree of difficulty for building a machine like this. Any advice would be greatly appreciated.
JPR
Message edited by jproadrage on 05-12-2009 at 10:10:19 AM
Sponsored Links
http://www.newegg.com/Product/Prod [...] 6811129045 $99.99 Free Shipping*
Antec NSK6580B Black 0.8mm cold-rolled steel ATX Mid Tower Computer Case 430 Watts 80 PLUS Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6813128374 $259.99 ($239.99 after $20.00 Mail-In Rebate)
GIGABYTE GA-EX58-UD4P LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6819115202 $279.99 Free Shipping*
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6820145233 $204.00 Free Shipping*
CORSAIR XMS3 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory - Retail
Compatible with Intel Core i7 series CPU for Intel X58 motherboard
http://www.newegg.com/Product/Prod [...] 6827136152 $24.99 Free Shipping*
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner - OEM
http://www.newegg.com/Product/Prod [...] 6822136074 $54.99 Free Shipping*
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Comb [...] mbo.186064 Combo Discount: -$20.00 Combo Price: $149.98
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6814150320 $75.99 ($55.99 after $20.00 Mail-In Rebate) Free Shipping*
XFX PVT96OSDFH GeForce 9600 GSO 768MB 192-bit GDDR2 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Total: $1,204.92 | $1,164.92 w/mail in rebates
Message edited by Why_Me on 05-12-2009 at 10:23:04 AM
Reply to Why_Me
Currently, there aren't any 4gb memory modules for the i7, only 2gb modules and the maximum number of slots on motherboards is going to be 6. So upgrading the ram to 24gb means tossing out the old sticks of ram, for very expensive 4gb modules, when they hit the market, and I don't know when that will be.
But for the other components you are looking at something like this:
Motherboard: Asus P6T $250
i7 920 CPU: $280
12gb DDR3 $150
Hard drives: 2x WD3200AAKS $110
GPU: HD 4350 $36
Case: Any cheap ATX, $30-50
PSU: Corsair 400CX $50
OS: $100
Optical Drive: $25
Putting a PC together isn't that hard, and if you are comfortable plugging in power cables ect then you should be fine doing it yourself, and you will save a lot of money if you don't go with an off the shelf system, as well as being able to cater it to your specific needs.
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
Thanks for the quick replies. Thats a pretty doable price point for me.
The ability to upgrade the RAM is a WAY down the line consideration, 12 GB will give me plenty of headroom for a while so I'm not worried about filling all six ram slots.
JPR
Reply to jproadrage
- -1 +
I am wondering why you think you need an i7 just to stream audio.
Reply to jsc
This isn't typical audio streaming, its for a high end orchestral sample library/engine and the head engineer over at the company is recommending i7 for any new builds. Its surprisingly easy to exhaust the polyphony even on high end machines, if I could afford it right now I'd build two.
JPR
Reply to jproadrage
Thanks for the advice, is a 400W PSU gonna give me enough overhead?
JPR
Reply to jproadrage
It should be fine as long as you don't get a powerful graphics card to go in your PC, but if you wanted to be sure you could go with a Corsair 450vx or 550vx. The 400CX should be adequate though.
GTX 260 Core 216
Reply to xthekidx
So here's what I've come up with, any advice or red flags would be much appreciated.
i7 920
Asus P6T
2 Kingston 6GB (3x2) 1066 Triple Channel kits
3 500GB WD Caviar 7200 SATA drives
Corsair 550W PSU
Asus HD 4350 PCI Express 2.0 x16 video card
Sony Optiarc 24x SATA CD/DVD drive
Cooler Master Centurion 5 CAC-T05-UW Case
Vista Home Premium 64 (maybe windows 7 64 beta)
JPR
Reply to jproadrage
500GB drives tend to be slower than 640GB or 1TB drives. I would get three WD6401AALS drives or a WD1001FALS.
Otherwise it looks good.
GTX 260 Core 216
Reply to xthekidx
thanks for the advice, ill look into those drives. Anyone out there tried the windows 7 beta?
JPR
Reply to jproadrage
thanks but I dont need a soundcard, all audio and MIDI goes from the slave to the master over ethernet
Reply to jproadrage
There are 1159 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
