Congratulations!
Quote :
none of the bios updates says it address this issue but who knew!!
Yeah - GB (and, well, everyone else in the business) is painfully sloppy about 'changelogs' for their BIOS; at least half the time, you have really no idea of what a new BIOS addresses... I do industrials, so I have to be 'anal retentive' about documentation; if they get sloppy, somebody's machine doesn't boot; if I get sloppy, an operator manages to cut off a hand!
Quote :
decided to try something drastic and dangerous
You've got that exactly right! @BIOS ruins more GB MOBOs than the next five causes combined. The problem appears to be that, unlike the BIOS' own flasher, or GB's FlashSPI, the @BIOS program is able to 'overwrite' the BIOS' bootblock, which, unfortunately, contains the code which does the DualBIOS 'recovery', to 'save' a defective flashing. Once this is done - the board is 'bricked', i.e., only good for propping open a door (and the actual brick does a much better job of that, too!), and the only fix is to wait for an RMA...
Comprehensive instructions for the other BIOS flashing methods are here:
http://forums.tweaktown.com/f69/bi [...] ide-27576/
