Hi,
I'm just pluggind up my PSU to all the compnents on my Asus P5QC.
On the 8-pin EATX12V CPU power socket there is black plastic cap over half of it for 4-pin users. Does anybody know how to get it off because I don't want to rip off the socket and need the 8-pins. Thanks for reading.
Usually they just lift out. At most, it may have a clip. Look at the 8-pin connector from the PSU, it should give you a clue as to how to handle a clip if there is one.
If no clip, just slip a fingernail under from the un-covered side and lift it up. If there's a clip, do the same while using other hand to lift out the edge of the clip.
------------------------------Gigabyte MA785GM-US2H, AMD Phenom II x2 550 BE (4 cores@3.6GHz), G.Skill 2x2GB DDR2 1066 (820@CL4), Scythe Katana3, Hec 585W, Samsung 2232BW+, WD Caviar Black 1TB SATA, Sea 500GB USB, 12 IDE HDs w/Masscool IDE-SATA Convertors, Ugly Old Case, Win XP 32bit
Reply to mongox
I have a P6t Deluxe V2 and it had the same cap covering 4 of the 8 pins. My PSU (BFG 1200 EX) came with a split 8 pin connector (I'm assuming so I could use either 4 or all 8 pins.) This may be a dumb question but SHOULD i use all 8 for some reason? Or should I just leave 4 of the pins capped?
