NEW System: Same q6600, ATi Radeon 4890, PAtriot Viper 4gb, Corsair 650w PSU. gigabye x48 DS5
i have a couple questions/concerns:
1. I am having trouble overclocking my cpu. my stock volts is 1.32, is that normal? most people stock volts with this cpu are in the 1.2 range. I had to bump volts up to 1.34 to get to 3.0ghz and at 3.2 my system crashed 5mins into prime 95.
2. Should crysis run well on this new machine? I am running it on Windows 7 1680x1050 and with everything on vh it is very gittery. so i decided to run fraps and i set everything to high and all i got in battles was 10-20fps. this seems low for my system.
last: My cpu tems seem a little high. right now while i am typing this they are 38, 35, 32, 36. Under a couple minutes of prime 95 there wen up to 75c! When playing crysis though the highest they got is 50c.
sorry for all the questions but im just frusturated after spending $700 and it doesnt seem up to par, any help would be appreciated.
EDIT: I just got done playing Dirt with everything on Ultra and got a steady 40-45 fps. The only thing is it didnt look as good as when i had my 8800gt. the shadows especially looked bad, they had a purple tint around the edges of all shoadows and everything just look sub par.
Message edited by mat7861 on 05-13-2009 at 07:22:49 AM
are you using the stock heatsink. if so that could be part of the problem. I would also suggest reseating the heat sink no matter which one you have
------------------------------Intel Q9550(E0 stepping)w/Xiggy Dark Knight, EVGA 750i FTW MOBO, EVGA GTX260 Core 216 SC, G-Skill Pi DDR2 800 4GB(2x2GB), Western Digital 320GB 16MB/cache HDD, PC P&C Silencer 750W PSU, Windows Vista Home Premium 64Bit, Antec 900, Acer X223w WS LCD, Saite
Reply to jalpaugh1978
Why would you spend $700 to slightly upgrade your system, doesnt make any sense to me. Seems you could have just bought a better graphics card and got the same results.
I am using a THermaltake V1, i am gunna re apply the thermal paste today and see if it helps. And i spent 700 on a new mobo, gpu, and psu. mainly cuz my last mobo was a $30 pos and i figured i would be able to OC wit hthis one, plus its crossfire so i can add another 4890 later.
i think it hekped a little with the cpu, Windows experience rated the cpu 5.9 when OCed to 3.0 on the otehr board, and a 7.1 when i hadnt even OCed it yet on this one.
You only have 2GBs right? Thats the problem there ^_^...you need 4GBs...the game will use 2GBs while Windows uses 1GB...LOL. Crysis is a system hogg...
Message edited by Kill@dor on 05-13-2009 at 07:46:35 PM
Go into the BIOS and make sure C1E and EIST are turned off for now. When you get a stable OC, turn EIST on later.
I would clock the CPU down to 3.0GHz, and set voltages down to 1.2 or the lowest value. Thats for the CPU...
For MCH/ICH...crank up the volgtages for FSB stability...
For you RAM, i would change it to manual and increase the voltage to 2.0 or 2.1 depending on RAM specs...i think for that one its 2.1. The reference freqency should be 266 and the memory freqency should be 800.
I got it stable at 3.2. Im not too bummed anymore cuz anything that isnt crysis runs like a champ with all settings at max and AA. I did the same bench mark as www.pcgamershardware.com did on COD 5 and my computer beats out theirs with a 4870x2 by about 10 frames so that makes me happy. it must just be something with crysis... o well.
