SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, movies, internet, home work
PARTS NOT REQUIRED: Keyboard, Mouse
PREFERRED WEBSITE(S) FOR PARTS: Newegg, cheapest
PARTS PREFERENCES: Too new to be picky about this stuff
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Prob not
MONITOR RESOLUTION: all of the above
ADDITIONAL COMMENTS:
This is my first build. I am very new with everything. Ive done research to figure out stuff on my own but can only go so far. THANKs FOR YOUR HELP.
Also, Im just trying to build this comp up for gaming and movies.
The build is off to a decent start. Both of the motherboards you picked are crossfire capable, so I would swap the 9800GT for a 4770. You should also get a different HD. That HD is a slow, older model. Here's my suggestions:
I dont plan on using crossfire for a while (at least a year) do you still recommend using the 4770?
Also, on the 4770 will the 512mb matter? I was always told to aim for 1 gig of memory for video card?
Now, with what you recomended and the rest of the parts i put together would you feel it would be able to handle WINDOWS 7 and play most games really well with room for some extra??
The 4770 easily beats the 9800GT. In fact, the 4770 is very close to the performance of a 9800GTX+. Here's a review where you can compare the 4770 to the 9800GT:
Edit: Yes, that system will run Windows 7 just fine. I wouldn't worry about the 512MB of GPU ram either, especially at the resolution you plan on running at.
All I needed to hear! Thanks for the advice.
I plan on making those adjustments.
Another thing, kinda off subject...
My dad and I have been building this together. He kinda thinks that buying a computer already built might be a good option. So, im wondering for the price of everything above comes out to about $770 with shipping.
Is there any computer already built (from any company) that will be around the same price with everything including monitor that will be an equal competition??
Message edited by blakehanson on 05-13-2009 at 08:57:25 PM
I haven't seen any with that cooler at any of the main US retail sites. I also wish they would release models with that cooler. It seems more efficient than the models currently available since it exhausts the heat out the back of the case.
And will this new cpu work with the motherboard up above?
Also, What are the advantages of having a faster cpu for game play. Rather than having a better video card?(which i believe the 4770 is a good one, right?)
Thanks!
Oh yes it will and it is the Flagship AMD CPU, it has an unlocked multiplier that means easier and better overclock and it runs at 3.2GHz...
For this build im using a case i alreadt have. What im wondering is is there any cables, wires, any screws, or anything at all that wont come with each part that im going to need to purchase seperate for installing this computer?? Please give me a list.
any advice on the wires, cables, screws or such needed for a new build?
Everything you need should some with the parts. Screws and cables etc come with the mobo. The only thing would be if you wanted extra ties for cable management or something of that nature. (Zip ties!)
