Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply Thermaltake TR2 W0070RUC vs. OCZ ModXStream Pro OCZ500MXS
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply Thermaltake TR2 W0070RUC vs. OCZ ModXStream Pro OCZ500MXS
I am trying to decide between these two power supplies.
I have a matx case.
Thermaltake TR2 W0070RUC 430W for $20.99 after rebate.
vs.
OCZ ModXStream Pro OCZ500MXSP 500W (modular) for $39.99 after rebate
Obviously, I would love to save the $ and use it towards RAM for my build.
But am not sure which one I should go for and if its worth the extra $20 for the modular one.
Now, one lingering problem I see is that the Thermaltake only has two sata connectors, yet I have three sata devices.
So that might rule itself out
would appreciate the input.
Sponsored Links
That Thermaltake is is probably this one and is pretty much garbage
http://www.hardwaresecrets.com/article/332
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to DellUser1
Thanks - amazing review - that is the PS that newegg is selling.
I'm looking for a great PSU at a great price, i know its hard, but so far i think the OCZ Modstream is the only one right now that fits that criteria.
The components I have so far are :
# GIGABYTE GA-G31M-ES2L matx motherboard
#PENTIUM DUAL-CORE E5200 2.5G (800MHz)
Combo cost me $106
# Apex Micro ATX Tower
Cost me $25
# Video Card with HDMI port
Cost me $15
Objective is to build a powerhouse PC at a budget price.
Any other PSU you all can recommend. Otherwise will just go with the OCZ.
Reply to jiqbal
This is what I recommend:
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail $49.99 after rebate
http://www.newegg.com/Product/Prod [...] 6817341017
recommended by Anandtech.com
Message edited by evongugg on 08-17-2009 at 08:51:57 PM
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Thanks for the info - yeah that is the same line i was thinking, except the one i listed is the 500W for $10 less.
Reply to jiqbal
I would recommend something better quality and lower wattage, Seasonic S12II 330/380 or Corsair CX400 would be plenty of power for that system.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
There are 1338 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
