ive just built a new i7 920 rig with a ud5 mobo and 6gb gskill 1600mhz.... and it doesnt post....
when i power it on all te lights just keep flashing slowly ... the same thing happens even without ram ....
i know ive connected the ram in the right slots
wut could be the problem here ?
this is my first build so bear with me if ive missed something obvious
i had read this and i think ive done everything right
the prob is tht there r no beeps it just keeps flashin ... everything does the gpu included ... the fans r running ... i think it might be the ram ... i checked each ram individually
I was just going to say, check each DIMM individually. Hmm. Do you have a bent CPU pin? You'd have to remove the cooler and CPU to check, but just an idea.
Does the UD5 have an LED error display? does that give you any information, you could look up the code.
What if you try and boot it with no cards or anything plugged into it? Like take out your video card, unplug HD and DVD. Just to see if it boots and runs.
