This will be my first upgrade in 5 years, so it’s quite a big one. I would like your advice on some of the new hardware and what types of purchases I should make to get the best bang for my buck. I have been reading these forums nonstop for the past couple of days and still cant come to a conclusion, so I figured I would just ask all of you! I didn’t want to break this into a bunch of smaller posts so I figured this would be the best forums to do it on. Thanks for your input.
APPROXIMATE PURCHASE DATE: ASAP
BUDGET RANGE: $1500-1600
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming - 90% of it is WoW, the other 10% is FPS aka crysis, L4D, and RtS
PARTS NOT REQUIRED: the only things I WILL be keeping from the old computer are speakers, keyboard and mouse
PREFERRED WEBSITE(S) FOR PARTS: I don’t want to go through the hastle of building myself so I was thinking ibuypower or dell outlet.
PARTS PREFERENCES:
Should I splurge on a new i7 920, or stick with quad core or a phenom?
If I do go with the i7 920 I would probably have to give up crossfire or SLI to keep it within budget. Is a second video card really worth it in the first place for what I am going to be doing?
If I get only one card, would you recommend the 4870 or the GTX 275/285?
And last, the power supply, I have been reading that a good quality 750 watt is good enough to support everything including an SLI or Crossfire setup, is this what you would suggest?
OVERCLOCKING: Maybe - As far as a cooling, would a standard case system and fan work ?
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: This would also have to be included in my budget but I have also been thinking of upgrading my monitor for some time, preferably something I can play 1920x1080. Currently using Samsung syncmaster 192mp (http://www.overclockersclub.com/reviews/samsung192mp/). Thoughts?
Message edited by marmo on 05-14-2009 at 04:26:13 PM
Ummmm so why are you posting on the New System Build forum if you are planning to buy a boxed computer?
Just curious. Everyone in this forum is going to tell you to build it yourself. Fair warning. And they will all make fun of Dell for the price range you are looking at.
+1, if you are going to get an i7, it's best to build it your self, for the price we give you and parts, it will be atleast 500$ + anywhere on a prebuild then your looking at getting a monitor which will be around $800+ on a prebuild. build your own build please.
Meaning, we will hit $1600 on your build, the Prebuild will be $500+ or $800+ higher than what we give you.
Message edited by fullmetall on 05-14-2009 at 04:44:27 PM
I was curious as to what you guys thought I should use parts wise. There were no forums for posting about a boxed comp =0
Quote :
The sites, Ibuypower or dell, you in the u.s.a? cause if you are, havn you not heard of newegg?
I have heard of it and been to it many times, the thing is, I don't feel comfortable building my own from ground up. Its still an option though, and lets say I did order everything off of newegg, can I get some advice on the parts i listed above?
Just go to Newegg.com and start piecing stuff together, at least what you know. Post it on here with links and we can go from there. We just like something to start with. You tend to get more help if you already have a starting point that we can pick apart. And trust me we will, everyone has a different opinion, so you end up making the choice.
+it easy to build a computer anymore these days. The hardest part is installing the OS, and Vista is EASY.
Memory: tight timing: CL 7-7-7-24/ CL 8-8-8-21(is alright, tighter the better the performance, looser, more stability).
G.Skills/ OCZ/Corsair/mushkin.
DDR3 1600 (12800)
HDD: Western Digital Black(fastest out of WD's)/ Some Seagates are fine.
WD Black 640gb/WD Black 1Tb.
Case: Best mid Towers: RC-690/ Antec 900(902)/ Coolermaster Storm Sniper.
Best Full Towers: Cosmos 1000/Antec 1200/Coolermaster Haf 932.
PSU: for 1 single card, 750tx/pc power cooling 750w/ 2 cards 850tx or 1000hx corsair.
Should look at the i7 920 combo with its asus p6t motherboards aswell to lower prices.
optical drives you should look into yourself for your liking, Coolers, theres plenty of good coolers out there.
For instance: s1283v/Coolermaster V8/Truecooler/ blah blah and on and on.
The BenQ 24" seems to catch my eye for the monitor.
Message edited by fullmetall on 05-14-2009 at 06:00:51 PM
Thank you Fullmetall, putting one together right now and surprisingly i have the same specs as what you listed so far. Its getting kinda pricy though, might have to go a bit over my mark =/
Memory: The OCZ is good but I've read some people have to play with the timing since it's so low. I'd get this G.Skill, which is really good, and you won't have that issue.: http://www.newegg.com/Product/Prod [...] 6820231247
Motherboard: The ASUS P6T will be fine for your needs, I have it and OC to 4GHZ. THe PCI-E are layed out nicer to. The Deluxe is nice, but you can save $30 if you go non-deluxe: http://www.newegg.com/Product/Prod [...] 6813131359
With all this it puts me at 1604. Where would be the best places to get rid of things without seeing too much of a performance loss with the games i mentioned above (wow, L4D, crysis)
- The 850W PSU is overkill, stick with a 750W PSU, it is enough for your system and 2 good cards
- the ANTEC 1200 is expensive and BIG, do you need it? (fat trimming, but get what you want the case is WHAT you do see)
- I wouldn't get the 4870 since you can get the Sapphire 4890 for $205 after coupon and MIR. I'd start with 1 for now. Trust me,at 1920x1200 it will be great. You can always add a 2nd down the road when needed and they will be cheaper. (trim the fat and get a single better card)
- Cooler, unless you plan to Overclock your CPU you can stick with the stock cooler that comes with the i7.
Thanks so much again! looks solid, tried to build the same thing on both dell and ibuypower and they were an extra 250+ each
I am going to keep the cooler ive decided. I have a very lazy summer so over the next few days while the parts come in i am going to read up on overclocking, hopefully its worth it. One other thing, how do i get windows 7 beta without windows lol =(.
Message edited by marmo on 05-14-2009 at 09:42:23 PM
mines the exact same as fullmetalls down to the combo processor mobo. Except i had to put vista in there =o totaling about 1587 after rebates. I also ended up going with the spectre monitor.
Yeah, ended up getting both. Ive been doing constant research on the cooler v8 and CM 690 case. apparently they will work together without too much issues ( i might have to remove the case fan). The only concern I have now is the thought of actually applying the heatsink and using the compound. The reviews I have read on the v8 say its a huge pain to install, as a first time builder im a little iffy heh.
