Hi
I just bought i7 with msi x58 pro motherboard, 4 gb gskil ram, 1 tb hdd, 4670 saphire card.
the problem i am facing. i am not able instal winxp or win 7 os
tried a lot
it show blue screen error while installer "bad pool caller" on winxp with service pack 2
in win7 it showed disable bios memory and cache error , some time blue screen ( 0x000008e,0x8bd597f7,0x8875db2c)
i even updated latest bios also
i am not able to judge whether the graphic card ,HDD,or Ram causing this issue
i dont know were this issue need to be addresed . sorry for multiple post
Sponsored Links
1. Clear CMOS and set every thing to standard settings. Make sure RAM voltage is correct. (btw, WHY do you have 2*2GB on a X58 board???)
2. Get Memtest86+ and check your RAM.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Right on with that, also i would remove all your hardware and put them back bit buy bit, it could be the ram is bad...or the video card could be doing it...too bad you dont have onboard video...does your BIOS have a S.M.A.R.T feature for the HD? could be bad hard drive on boot up. I had a bad hard drive that kept poping up BSOD just as i was about to get in the vista install screen, and i found out it was going bad.
Message edited by fatsauce on 11-04-2009 at 12:09:30 AM
Reply to fatsauce
Mostly your RAM... also, just use 3 GB, you got a tripple channel interface. ALso... a 4670? WTH are you thinking?
Buying a cheap Athlon X2 would have give the same gaming performance for 500$ less...
Reply to redgarl
Well im sure hes going to upgrade to something better in the future..that 4670 is in the prehistorical era
any luck yet redgarl?
Reply to fatsauce
Thanks everyone just removed one ram i am not getting any errors during installation .
i was able install win 7 need to check tonight
thanks once again
Reply to max3dlover
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Help needed i7
There are 919 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
