Help-Graphics card?
Forum Graphic & Displays : Graphics Cards - Help-Graphics card?
hi im looking for a new gfx card for my main comp so i can play cod4 on.
some info on computer
motherboard is: MSI Amethyst-M
processor: AMD Athlon 64, 2200 MHz 3700+
Ram: 1GB SDRAM PC3200
the one my friend thougth would work is
http://cgi.ebay.co.uk/Gainward-Bli [...] 1|294%3A50
tht is the link to it.
thnks for the help.
Sponsored Links
I feel you would be better off buying a new 9600GSO rather than a used card from ebay.
Reply to mousemonkey
how much would that cost as im not looking to spend much i forgot to put tht in my first post
thnks
Reply to xN m F
The airflow in a HP/Compaq system is probably not enough for the passive cooler on that 8600 GTS to work properly. I agree with the mousemonkey also about ebay purchased items, they can be more trouble then they're worth. Look at a HD4670 or the 9600GSO in your area to see what prices are like. Here's 2 links to newegg (which i know you can't use, but may be helpful)
http://www.newegg.com/Product/Prod [...] 6814121319
http://www.newegg.com/Product/Prod [...] 6814131146
Reply to dirtmountain
so the one i linked wouldnt do but what happens if i used the hd side would it cope then.and here is a link to 9600 http://shop.ebay.co.uk/?_from=R40& [...] Categories hd4670 http://shop.ebay.co.uk/items/_W0QQ [...] &_osacat=0
so i shuldnt buy from ebay i should by from say pc world in uk.
Reply to xN m F
PC world?, NOOOOOOO!. Scan are pretty good I have never had a problem with their service and their prices are OK.
scan.co.uk so either the 9600 or hd4670 or the one i link so i could play on my tv.
Reply to xN m F
So long as you avoid ebay and PC World.
okdokey gd thing is im happy with scan as they take paypal so i l probalby go for scan. but to refernce which out of the 3 would hav bets performance with my machine
Reply to xN m F
I prefer Nvidia cards so I would go for the 9600GSO over the 8600.
my mate said my computer might not be able to handle but from wat uv said it shuld.
Reply to xN m F
What PSU do you have?
how do i find out my PSU would i find it on EVEREST coporate
Reply to xN m F
No, it's inside the PC case, so open it up and take a look.
is there any other way as i dont know were the box is but ill look
Reply to xN m F
Don't know where the box is?, now I'm confused.
see i was confusd till my dad said it is the box wi th compute rinside it
Reply to xN m F
were bout inside would it be
Reply to xN m F
right i thoink i hav it 230volts
Reply to xN m F
No, that is just the voltage that we use in the UK, you need to find out the make, model and most importantly the wattage.
http://img3.imageshack.us/img3/3140/pict0067vbg.jpg
right it says 300w inside it. does tht help u
Reply to xN m F
It should be OK, borderline OK, as a 9600GSO is in the 90 -110w range under load iirc, and is one of the few cards that can be run on a cheap/generic PSU.
HIPRO HP-D3057F3P
with 300w
some more info
Reply to xN m F
Sounds like someones got a smart mate. ;3 You should listen to her advice.
Message edited by Gin Fushicho on 06-06-2009 at 01:54:00 AM
Reply to Gin Fushicho
lol. I'm not saying Mouse monkey is wrong. I'm jsut saying your mate sounds like she knows something about computers , you should ask her.
she= a he and i did he said to come here and these guys or girls told me these gfx cards myt work.
Reply to xN m F
So he doesnt want to help then? and now I'm wondering if you iz a he or she and if your going to kick my ass in CoD4. lol.
im a he lol. no he done as much as he could as he is 13 so he is smart. and ull probs kick my ass on comp for cod4 as i havnt got it well i do but my gfx card wont take mehh so ill buy nvidia 9600 then from there on play cod4 as i hav it for xbox
Reply to xN m F
I'm guessing your young to. lol. all I can say is your probably going to be back soon even if you do get a new video card.
pardon but im not smart at thse thng so does this mean it will take it as in my comp take the gfx card
Reply to xN m F
yes i probaby will as i hav had gd help so ill will probs ome bak wen i get it but i know hwo to install if i hav any problemo ill be bak in a flash
Reply to xN m F
Well I hope you enjoy your 9600GSO its a great low power card.
thank u low but hey better qual thn thsi junk i hav the now
Reply to xN m F
does tht mean it will work fine wi my comp
Reply to xN m F
For online play another gig of RAM might help too.
how u mean and i think it ill be fine for just now
Reply to xN m F
I mean if you start palying online with a lot of people you will probably want 1 more GB of RAM.
now how wud i do tht?
Reply to xN m F
That PSU is the first thing to replace as whilst I feel that it will run OK it is going to be at pretty much max capacity and replacing it is probably going to be cheaper and easier than getting a gig of DDR 400 RAM, cheap RAM = £30 Vs cheap 500w PSU £15 - £25.
would th ebest thing to i to take it in to c world get psu from there but get the gfx card from scan as there cheap. so just a 500w would do and tht wuld be liek havin 400ram to make it better online
Reply to xN m F
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help-Graphics card?
There are 1195 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
