PSU & Case help.
Forum Homebuilt Systems : New System Build - PSU & Case help.
I'm building a new P.C (790GX, Phenom II 955, HD 4890, 1tb SATA 3gb/s HDD, 8gb DDR3 1333)
How hefty of a power supply do I need to buy, and would all of this fit into a mid ATX case?
Sponsored Links
http://www.newegg.com/Product/Prod [...] 6817139004
This should be more than enough
And it should fit into a mid ATX case, but which one are you using?
Reply to tidefan94
Here is another option that is a little cheaper:
http://www.newegg.com/Product/Prod [...] 6817341010
Do you have plans to overclock your system? And what case are you planning on using?
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
Tom's Hardware > Forum > Homebuilt Systems > New System Build > PSU & Case help.
There are 921 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
