Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Possible faulty graphics card--Need Help
Forum Graphic & Displays : Graphics Cards - Possible faulty graphics card--Need Help
I have-
core 2 quad q6600 GO @ 3.1 Ghz
4GB kingston ddr2 RAM @1066Mhz
GTX 260 216 edition Zotac
780i Motherboard
Whenever i run games inclusind crysis warhead, call of duty 4, GRID i get freezing, black screens, crazy colours and often they will crash but it alsways says its the driver,,, Im not so sure. Its all updated and its a new build, should i get a new one??
Any help would be nice.
Sponsored Links
Assuming you have the correct power; make sure you have the proper power plugs in place, if so and its under warranty I would send it in for a replacement or refund.
Message edited by ct1615 on 06-06-2009 at 10:16:40 PM
Reply to ct1615
^+1 first take off the OC
need to know PSU though
Message edited by mindless728 on 06-06-2009 at 11:24:25 PM
Reply to mindless728
jamespage17 wrote :
I have-
780i Motherboard
Oh 450W corsair PSU vx
Reply to jamespage17
mousemonkey wrote :
Is it the same without CPU OC?
HMMM not sure, could that realy be an issue?
First rule of OC'ing: results may vary. Put it back to standard and see what happens, can't get any worse can it?
Reply to mousemonkey
No, actually, there's no chance at all. We just like making you do ridiculously stupid things like slowing down your computer back to the speed that it was delivered at.
Come on, you came for help, at least listen to the damn suggestions. We'll help you out here, just help us help you and try the things we suggest (as long as they don't break/blow up your computer).
On that note, you say "it always says its the driver"... just in case, could we see some of these crash-messages verbatim?
Message quoted 1 times
Message edited by mlcloud on 06-07-2009 at 12:50:02 AM
Reply to mlcloud
na i wasnt sayinh hhhmm i dno if i should try that i was saying hhhmm no i dont think i tried that, so soz if that came across wrongly and how could i get crash message verbatim.
On a side note i brung it back to 2.4 and seems better, why does that help??
Quote :
[:mousemonkey]
jamespage17, have you ever checked your overclock for stability?
Reply to mlcloud
yer i ran prime95 for about 40 mins i think and had no errors and it seemed stable to me, thats why i dont understand my problem. I get extemely high temps though at full load i had 80C!!!
your cpu hits 80c on full load?
Reply to ct1615
Yer according to coretemp, i nearly crapped myself, u think its faulty?
Well, either your temp probe is wrong or you need better cooling/airflow to OC that far. What temp does it reach at stock clocks?
------------------------------ New Build : Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB >
Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > CM Hyper 212 Plus > Other: PII 940/Gigabyte 790GX/4850 1G
Reply to EXT64
At idle its generaly 44-53
Its running pretty warm. and..... als oI had the same problems with my 9800GTX+ then I bought me a GTX260 and never had the problems again. if the problems are jsut in Crysis try lowering some settings. if you still have problems then its a faulty card like my 9800GTX+
Message edited by Gin Fushicho on 06-07-2009 at 03:02:08 AM
Reply to Gin Fushicho
i dont think i would OC your CPU until you get a better heat sink and fan
Reply to ct1615
80c is a bit high for a q6600 but i dont think it will go above 71c while running games.
Anyway, he said it gave the driver error so i'm thinking its an overall heat issue that is probably making the 260 give up. No overclock = less heat, that's why it's better at stock. Stick a fan on the side of your case or get an extractor fan for the pci slot and it should help a lot.
Message edited by jennyh on 06-07-2009 at 04:41:38 AM
Reply to jennyh
There are 1233 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
