Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > My PSU Has 2x 4Pin 12v Connector But My Mother Has 1x 4Pin 12 Conector
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - My PSU Has 2x 4Pin 12v Connector But My Mother Has 1x 4Pin 12 Conector
I Have An MSI P45 Neo Motherboard With One 4Pin 12v Connection, But I Have Bought A PSU Powersuply Unit 750 Watts With 2x 4Pin 12v Connectors. Now Will This PSU Work fine With My Mother Board?
MSI P45 Neo
8gb Patriot 800 Mhz DDR2 Ram
Intel Q6600
8800GT
PS: I have Read About Some Safety Thing On Mother Boards That Is TO be Removed, Perhaps It Only Applies To Some Mother Boards But Kan Someone Explain This TO Me Also Thanks. :hello:
Sponsored Links
Yes, your psu will work with your motherboard. Just plug in one of the 4-pin, 12 volt connectors. Some motherboards require 4 pins and some motherboards reuire 8 pins. Your psu can supply power either way.
Message edited by JohnnyLucky on 08-20-2009 at 08:48:49 PM
Reply to JohnnyLucky
Put your PSU 1 x 4 into your Mother.
Reply to knotknut
it's fine the two four pin connectors snap apart and you use half of it. Next gen boards need extra power for all the PCIe slots so they have the eight pin connector.
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
Thank You My Dear Brother, You Are Right It Works. I Appreciate Your Assistance. May Allah Bless You And Your Family. Thank You.
Message edited by randomizer on 08-23-2009 at 09:20:19 AM
Reply to MrPioneer
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
