I am building a new PC, my budget is currently 1200-1300 dollars.
The Specs are as Follows:
GTX275
Phenom II 955 BE
790FX based mobo
6 gigs of DDR3
Coolermaster case with 4 120mm fans
1TB Seagate SATA HDD and a DVD-RW.
Windows 7 Pro.
The question I have is about the power supply for the rig. I currently have a Thermaltake Toughpower 850W psu that is in my current PC. I believe it is in the 62 Amp class. Will this be enough? The specs as listed eats up the $1200 I had budgeted. I really do not wish to spend the $300 or more that it will take to buy a beefier PSU but I will if I must.
Does that include Amperage? Its mainly the Amps I'm worried about. I know Watt wise I will be more than ok. I just want to make sure it doesn't eat up more amps then a given 12V rail can supply. I think I accidentally burned up my x1950xt GFX card that way on my previous PSU(it was a 36A/650W PSU). I just want to make sure I don't do that again.
That includes amperage.
Your previous psu probably wasn't very good , only 36 amps out of a 650 watt psu isn't a good sign,most good quality 550's can do better than 40 amps.
------------------------------q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
