Following is my planned first build. Please review and critique it for me.
The intent is to use it for 3d applications (Maya, 3ds Max, Truespace, Blender) and CAD
applications (Pro-e Wildfire and Solidworks). I also want to fool around with some VMWare stuff)
Anyways let me know what you guys think...
Motherboard: GigaByte GA-P35-DS3L Intel Socket T LGA775, P35 Express, ATX, 8GB DDR, 1333MHz FSB
(Not sure about this mobo but it is reported to work well with the Q6600)
http://www.pricegrabber.com/user_s [...] id=9143561
VIDEO CARD - EVGA NVIDIA 8800GTS ,512 MB, 256 bit DDR3,PCI-E 2.0 16x
(I am leaning towards this card because it is SLI capable and if it runs my apps okay, I may get 2 and run in SLI.
Also, it can be softmodded into a Quadro FX4600, if need be, for the OpenGL support.)
was there something missing from my first post? I have not had any responses so I am at a loss what is missing? Oh, mu budget is around $1200 less the monitor, keyboard and mouse which I plan on getting locally anyways.
Pro-e , and some other of my applications, require opengl support. The gt260x can be softmodded to the quadro fx4800 but I can find no Pro-e support for that processor. That is why I picked the 8800 gts or gtx, same archictecture. It can be modded to the quadro fx 4600, which is supported.
It is my understanding that there is a problem with windows drivers for the i7. Again, that creates an issue with Pro-e, which definitely does not support or is supported by Windows 7. That would force me to Vista Ultimate which is okay, just cost $75 more that V Home premium which Pro-e supports.
So my plan is to load V Home Premium as a base OS and then to set up some guest OS's with VMWare Worstation to run the applications under, either a Windows XP Pro or some flavor or Linux as the guest OS's.
As I stated in my original post, I am building for 3d design and modeling and everyday computer use.
Does the build you suggest take care of my intended use?
the i7 will own the Q6600 in 3d rendering and if needed you can get an extra 3x2GB set of ram but save money and get 1333mhz ram because the i7 can't run 6 dimms above 1333mhz.
I did a bit of research on the windows 7 thing and it looks like people are having success running vmware workstation as well as pro-e rev 4.0 under it.
I saw somewhere where the i7 920 is easily OC'able to an i7 965 too.
I think I am going with the build why_me suggested.
I can always set up appliances under vmware for linux and run pro-e under linux - rev 3.0 anyway.
This build should be future proofed for awhile, don't you think?
okay, I placed my order on Saturday and the parts should be in this week.
After I put everything together, are there some tests or performance benchmarks I should do before I put it into use?
Also, I am wondering if I should go ahead and order another vid card so I can start out in sli mode - any thoughts?
Hey-
Sounds like I'm a bit late to the discussion but am in a similar situation; I am an architecture student building a system to run mainly Revit, Rhino, Sketch-up, AutoCAD, 3dMAX, CS4, Blender, Kerkythea, etc...
I am admitedly a novice to system building, this will be my first, but from the research I have done so far it does seem to me that Why_me has given you some very solid advice, the i7 will future proof your system much more than the Q6600. That being said, I'm wondering why you are choosing to go with a gaming graphics card instead of a workstation one. Is there a benefit to going with the gtx260 instead of something like this:
I realize it's not the most impressive of the quardo series but seems to be a great card for the price and is specifcally tailored for what we do.
Sorry to jump in on the discussion so late, and hopefully I'm not causing you any unnecessary stress or buyers remorse, just seems like a lot of people on here are gamers and may not be considering the compatibility w/ 3d modeling/rendering programs.
Let me know what you think...
Thanks
Message edited by number9 on 05-26-2009 at 06:33:24 PM
there are some discussions over at techarp on methods to softmod consumer geforce as well as ati graphics cards into workstation level cards.
Many of the consumer (read gaming) cards have the same architecture as the quadro cards. It seems that the workstation cards have some level of stability that is "programmed" into them by the manufacturer. Additionally, there is some additional support for the workstation cards. But those are things that drive up the cost of the card.
I am going to try the gtx card out first as it supports opengl and then try a software mod before I spend the perhaps unnecessary money on a quadro.
hope that helps - I will post back after I get everything together, tested and running the way I want. Might be a little while though...
