Will ATX12v work in EPS
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will ATX12v work in EPS
Hi,
My Abit motherboard requires an 8 pin EPS supply, however, I have been running it via a 4 pin ATX12v supply, although the manual states it would be "recommended" to use an EPS plug. Is there any real need to upgrade my PSU to one with an EPS plug or will my current PSU with a 4 pin connector do the job.
Thanks
Sponsored Links
You should be fine the extra four wires are to supply more power for the PCIe lanes
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will ATX12v work in EPS
There are 832 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
