Tom's Hardware > Forum > Graphic & Displays > ATI > No Audio Sound
Moterboard: ASUS P6T SE
Processor: Core i7 920
Graphic Card: XFX 4850 1GB
OS: Windows Vista Ultimate 64bit
I just hooked it up to my 32" LCD TV through a DVI to HDMI Cable and now i do not get any sound. Any Help?
Message edited by thejj924 on 06-08-2009 at 01:55:03 AM
Sponsored Links
Connect the SPDIF wire from the motherboard/sound card to the video card.
If there is no connector on the card, you will have to use DVI.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
there is no SPDIF on the Graphic Card; i dont beleive so atleast
This is the Card.
http://www.newegg.com/Product/Prod [...] 6814150351
Message edited by thejj924 on 06-08-2009 at 03:19:01 PM
Reply to thejj924
For the 4850, you should just have to use the DVI->HDMI converter. I think you have to change something in the sound tab of the control panel though...
(I've never tried this myself, obviously)
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
tried it didnt work says is unplugged. tried the Realtek HDMI Audio Driver didnt work. i figured id ask for help after i tried everything from google
Reply to thejj924
The HDMI Audio driver should come as a part of the latest Cat 9.4 and Cat 9.5 drivers, so I would recommend you to uninstall any other drivers and then reinstalling them over again.
You should be able to right click on the Audio Devices inthe system tray and ATI HDMI should be listed there, selct it and then click on Set Default.
I also have Vista 64 Bit but the HD 4870 1GB in Crossfire, and I've never had problems with Sound over HDMI.
The only issue I had was, when running FarCry 2 in DX10 sound over HDMI would not work, but that was resolved in the last Cat 9.5 drivers.
Hope you get it fixed.
Cheers
Message edited by Euphoria_MK on 06-08-2009 at 08:17:54 PM
Reply to Euphoria_MK
just tried that, reinstalled Cat 9.5 from xfx website. did not work, anybody else have ideas (other than be buying speakers). i normally do not have a problem with this stuff; but i have tried everything.
1) searched google. for 'ati hdmi audio drivers' came up with Realtek. mine is ALC1200;
2) uninstalled and reinstalled drivers for EVERYTHING!!!!. did not work
3) uninstalled drivers for video card then uninstalled cat 9.5 and reinstalled both. DID not work.
anybody have any ideas?
Reply to thejj924
What is the hole on the top of the card, a bit back from the Xfire connectors?
Reply to mousemonkey
honestly i dont know; is that a spdif connector?
Reply to thejj924
You shouldn't need an SPDIF header though.
xx924, you probably need to disable your other onboard audio, and then go into the realtek audio properties
(which should show up as a red speaker icon on the start bar).
From there enable the audio via HDMI, and then go into properties.
This is the easiest pic I could find which shows all the information in one shot;
http://i30.tinypic.com/iz9pvl.jpg
Message edited by TheGreatGrapeApe on 06-09-2009 at 02:16:23 AM
------------------------------ You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - RED GREEN. GA to SK
HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
Well that's what I was wondering. But the TGGA has your back.
There are 1082 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
