Hey guys, I'm working on building an i7 system and I've been stuck on which case to get for a while now. I'm not going to do any liquid cooling, all air, and it needs to be $200 or less. I'm looking for the best cooling, airflow what have you.
I plan on adding fans to every extra slot available, so when suggesting a case please try to keep in mind that I'm not looking at them at stock level, but after every fan slot has been filled.
I have the CoolerMaster HAF 932. Ventilation, airflow, and cooling are excellent with the stock case fans. No need to replace any of the case fans even with an overclocked Core i7 system. No need to add additional case fans.
Why do you need all those fans? Are you are hardcore gamer into extremely serious overclocking on a do or die mission to save the universe from alien invaders? Resistence is futile!
Google "HAF 932 review" (or any other cases you are interested in) and scan some results for yourself.
Although I'm still trying to figure out how many folks need 6 optical bays, etc. Make those things removable so the rest of us can get better air flow.
Message edited by Twoboxer on 08-22-2009 at 07:28:59 AM
I actually plan to do HD live broadcasting (720p most likely since that's what sites support) while gaming. I'll probably only clock my CPU to about 3.3, that'll probably be fine, but I'll go higher if needed. I plan to live broadcast for long periods of time, even up to the 12 hours or longer at a time marks. Live broadcasting takes a lot of processing power (for example, I have a simple Pentium D currently, and broadcasting at 640x480 resolution while playing World of Warcraft on lowest settings, maxes my processor. I want to do 1280x800, if not higher, resolution, and on higher end games) which can leave the processor running at high loads for long periods of time. Will I need all that extra cooling? I have absolutely no clue, I'm just worried about killing things.
Here is a very good Full Tower Case you should look at, but it is abpout $50 over your price range. Zalman GS1000 Full Tower Server Case w/ Custom Bolt on Window - Black $249.95
http://www.performance-pcs.com/cat [...] s_id=24922
If you are gonna get the HAF 932, you might wanna get it on amazon cause its $155 with free shipping... I'm not sure how much shipping is on new egg for that gigantic case...
