PSU, i would recommend swapping it out for a similar power corsair, seasonic, or pc power & cooling, apevia is a really bad brand (aka, that 680 may only give u 450)
that 46 amps or amperes are needed on the 12v rail in order for the GPU to be powered in a system, usually the amps are for the whole computer and are usually exaggerated, even so that PSU can't handle it and that PSU is poor quality, get rid of it, if it goes, your whole computer could go
they would probably work, but the new PSU isnt much more than those units that are just for the GPU's, and like i keep saying the current PSU is really bad, you need a new one anyways
He means that your overpriced 680Watt power supply, produces no where near that much, it can handle at best 550Watts on its 12 volt rails but likely something closer to about 480 which a good 500 Watt PSU can handle easily for less money too. Basically buy smart not just because its shiny.
i have a q6600 at 3.0 ghz
t260hd monitor 1920 *1200
2 seagate hard drive 640 GB total
i external 500 GB
GA-P35-S3G
6 GB 1066 5-5-5-15
apevia iceberg
1xcd
1xdvd
1xdvd/cd
Sagitta 2 case
air cooled 25C -- cpu
indeed......
i will switch out my psu in a 3 months but i have to stick with the current psu now
so
will i be able to run a 285 gtx on the apevia iceberg 680 watts????????????????????
indeed......
so
please tell me i can
I wouldn't chance it, unless you like indoor fireworks in which case go for it.
i external 500 GB
GA-P35-S3G
6 GB 1066 5-5-5-15
apevia iceberg
1xcd
1xdvd
1xdvd/cd
Sagitta 2 case
those are my specs
The Apevia is crap. I'd give it a good boot into the nearest rubbish bin before it costs you money. At your res., a 285 would be overkill. A 275 would be appropriate for most games. Ever thought about using an ATI solution? You can get very similar performance, and spend a lot less dosh.
But then again, it's your money to throw away as you see fit.
^ For an apevia??? Care to re-think your 'shocklingly wrong' statement?
Yes for an apevia, because nvidia recommend minimum 680W with +12 Volt current rating of 46 Amps and apevia iceberg 680W have 46A. So it will be fine to power a GTX295.
Also do you care to re-think your shockingly wrong statement?
For the record, I did attempt to put loads greater than 16A and 18A on the 12V rails and anything I put on them that added up to more than 34A, which is over spec according to the combined 12V rail rating, the PSU shut down. Even when the 3.3V and 5V were lowered almost all of the way down. Needless to say, the "maximum" amperage capabilities of each 12V rails are grossly unrealistic.
Each rail can output that much, however the primary power source for the rails rarely is capable of outputting the max current listed for both rails at the same time. For most of them it seems that the two rails combined can only handle about 80% of what their sum would indicate.
Yes, I do... Not only will the apevia not power a 295, but you seem to have a cranial-rectal dysfunction.
OP if you are keeping the psu for 3 months i would recommend you don't use your computer for that long (those apevia PSU's are that bad)
OK..I totaly agree
BUT!!
1. Right now i am probably pulling around 250 or 300 watts at max nothing special. I think the psu can handle at least up to 400 watts stable.
2. What if i get a dedicated power supply for the 285/295 gtx. I mean around 450 watts or 300 watts dedicated gpsu. With this, the current psu won't be affected. I really don't want the main psu to get any load, no matter if it is an apevia or a corsair or a kingston. What i am trying to basically ask is, what if i get a dedicated power supply???? (It is about 59.99 or 79.99)
Seriously, I am not trying to be stubborn.
Nobody is talking about the dedicated power supply...does that have any problems...
THE VISIONTEK ONE 450WATTS
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16817206001][/url]
THE CHEAPER FSP ONE 300WATTS
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16817104019][/url]
