NB needs Overclocking help
rumbled
Hey guys I have my rig running stable at 3817 MHz CV = 1.296. I also have my FSB at 2200MHz does that sound about right? I noticed a temp drop of about 5* once I raised my FSB 200MHz. Should I move it up to 2400? Thanks for the advice....
Amd 1090T black edition 3.2 mhz OC 'd to 3817MHz CV= 1.296
Gigabyte GA-890FX MB
16 GB 1600 Mhz Ram Kingston Hype X 9,9,9,27
NZXT Phantom Case with 7 fans.
Cooler Master V8 idle 23* load 38*
ThermalTake 650 Watt PSU
(2) 1 TB HDD 7200 RPM
Seagate 2 TB 5200 RPM ext HDD
Radeon 1 GB HD 5570
EVGA 1 GB HD 8400
(2)24.5 viewsonic LED's & 47" Vizio LCD
Win 7 Ultimate 64 Bit
Radeon 1 GB HD 5570
EVGA 1 GB HD 8400
answer
Last reply
More about overclocking help
Hi and welcome to Tom's forum.
HT = 2000MHz, something above that won't give you any performance increase.
FSB= 200MHz since you have a BE CPU you don't need play with it.
NB = For Thuban cores (like 1090T), you can hit the 3GHz with a little rise in CPU-NB voltage.
What setting are you using for the CPU-NB option?
Overclocking
Related Resources
- Q6700 Overclocking Questions
- How Far Can I overclock my AMD 1100T Thuban on the Stock Cooler?
- Overclocking help
- Help a complete newb at overclocking
- Overclocking Amd 965 3.4 ghz for the first time help
- Overclocking
- I7 860 Overclocking & Memory
- E4300 overclocking question
- A newbie’s guide to Overclocking an Athlon XP CPU
- Phenom II x4 965 overclocking help
- Help with overclocking amd phenom ii x6 1090t black edition
- ABIT AI7 - Pentium®4 - 2.6GHz - Overclocking advice :)
- Overclocking amd 965
- Overclocking question
- P4 overclocking and RAM
- Guide to overclocking the A64
- Overclocking Ram On AMD Platform...
- Asus P5N-E Overclocking confusion
- Overclocking my new rig
- Help with overclocking and Vcore voltage
