Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > M4A78 Wont post with 4x1GB, but works with 2x1GB! HELP!!!
Forum Motherboards & Memory : General Motherboard - M4A78 Wont post with 4x1GB, but works with 2x1GB! HELP!!!
I have a new build I set up today with an Asus M4A78 Plus Mobo, Phenom II 955, 8800GT, and 4X1GB DDR2 sticks of PC2-6400 ram. I know that individually all the components are good. If I only install sticks in a1 and b1 it works perfectly, with any combination of ram. Any combination involving a2 and b2 the mobo wont post. Have tried updating bios as well. PLEASE HELP ME!
Sponsored Links
Need to set ram voltage in bios with just two chips initially to manufacturers specifications which generally are higher than motherboard default voltages. Add additional 2 chips and if they come up test for alittle while.
In some circumstances with may need to up voltage to cpu memory controller slightly. The latest Phenom II 965 stepping C3 is reported to be the first AMD phenom II chip certified for (four) memory modules.
Reply to roonj
There are 1135 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
