Tom's Hardware > Forum > CPU & Components > Other Components > Problem with USB ports
I'm working on Windows XP professional version 2000 SP2. The problem is when ever i try to plugin a USB device, the OS is crashing and not responding to anything except the manual restart button on the cabinet.
But the ports are working all fine without any trouble when i start my pc in Safe mode.
How do i get my USB ports to work without any trouble even when i boot my OS normally?
Sponsored Links
virus scan
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
It is most likely on of USB device drivers that is causing problems.
Unplug all USB devices. Go to device manager, select to show hidden devices, uninstall all usb device drivers one by one followed by usb hubs and controllers, restart PC and let it install new drivers.
Plug in Your devices one by one and install drivers for them( for some devices You might need to install driver before You plug it in). If it crushes with one device then either driver is bad or device is faulty, at least You will know which is causing the problem. Now you can try to download different versions of driver for that device from manufacturers website to see if that solves problem.
Reply to ainarssems
If it's a driver issue you may find this helpful
http://www.nirsoft.net/utils/usb_devices_view.html
Reply to 505090
There are 1133 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
