Antec 900 Fan Speed
Hello everyone. I have just assembled my new PC in the Antec 900 case. I unsure at what level (low, medium or hight) I should be setting the case fans at. I want to get the right balance between airflow and noise.
Just to give you an idea of what's inside my case, here are the big heat generators:
Intel i7 920
GTX 260
Corsair 750 Watt PSU
6GB Dominator RAM
650GB Western Digital Hard Drive
There are 4 fans in total. Two at the very front, mounted in the hard drive cages, one very large fan at the top (200mm) and one at the very rear of the case. They are all adjustable in their RPMs.
What would you set them at?
Cheers guys.
4 answers Last reply
More about antec speed
  1. I would monitor the temperatures with Real Temp and HWMonitor and adjust the fans accordingly:
    CPU-Z
    Real Temp
    HWMonitor
  2. What kind of temperature should I be trying to maintain?
  3. Here is the info for Intel CPUs:
    http://www.tomshardware.com/forum/221745-29-sticky-core-core-temperature-guide
    GPUs can run fairly hot. 80C is OK.
  4. I would set them all on low for starters and see how you do. Most likely, you will have no instability problems.
    My system has similar components in a case with lesser cooling, and I have no problems. If you want quiet, a good oem cpu cooler can help.
New Build Cases Antec Fan Speed Systems
