Guys, after plugin the memory sticks out of the box the motherboard identifies it as being 1066mhz (8-8-8-20 when it should be 9-9-9-24), and there is a config there written "Profile1", if I put it on, it changes the memory to 1600mhz, 9-9-9-24 and voltage to 1.6V (I think its at 1.35 without it). The only problem with that is the system being a little unstable.
Also, the motherboard temperature seems to be way off (58 C), and the clock shows 3100mhz? I haven't done overclocking.
The initial boot up is going to be at the SPD settings. Look at the SPD tab in your screenshots. Because of the memory clock speed of your CPU, the motherboard is selecting JEDEC # 3.
------------------------------Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
