Need Cooling Help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Need Cooling Help
Hey all - I had a few questions I need a little help on regarding cooling.
First things first - How hot should a computer that is water cooled and have 4 fans get? Mine is getting to around 50 C.
Next - Do I need to change the water coolant in my computer from time to time? I haven't changed it in about 2 years.
How would I go about cooling my system significantly? - unfortunately I am in a room in the house that gets a little stuffy and am unable to relocate. Adding fans - I feel would just recirculate the already hot air.
** I have purchased a huge 32 in fan and have it blowing straight into my computer and it seems to not effect the temp at all. **
This is the case I have currently.
http://www.newegg.com/Product/Prod [...] 6835108092
Thanks fer yur time ~~
Sponsored Links
Buy an air chiller for your room, you'll see a big difference. Computer temps depends on room temps. Other than that, I never touched any water cooling system so I can't really help :-/
Reply to abswindows7
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need Cooling Help
There are 548 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
